Smooth Vertices called from the F3 operator search will put you in a modal without knowing [doesnt execute immediately] #72069
9 Participants
Reference: blender/blender#72069
Operating system: Linux (Ubuntu 18.04)
Graphics card: GTX 1080TI (NV driver 440.26)
Broken: 2.82, (blender-2.82-7af560438966-linux-glibc217-x86_64)
Worked: 2.81 released
Smoothing Vertices
in edit mode when called from the F3 operator search will leave you stuck in modalExact steps for others to reproduce the error
Simply subdivide the initial cube a few times and called the operator from the F3 operator search
You are in a modal, operator only executes after first mouse click (with unwanted results depending on mouse position)
Added subscriber: @JonasPrintzen
#73445 was marked as duplicate of this issue
Smooting in edit mode stopped working (works in XXX)to Smooth vertices in edit mode stopped working (works in 2.81)Added subscriber: @zazizizou
Thanks for reporting. I can't reproduce this on macOS with today's master (last commit is
f1ac64921b49eaea8658d144754a1a532198c720
).A unit test for the smoothing operator will be added soon as part of D5357
Added subscriber: @laurijh
There seems to be a difference between the menus in how the tools are activated. From Vertex menu / Smooth vertices there is instant effect and the tool settings appear in the lower left corner for further adjustment. The toolbar tool requires you to first drag left or right with the mouse to modify your mesh and afterwards pops up the tool options on the viewport corner.
However, it really is confusing that only a subset of the tool options are shown in the sidebar under Tool / Active Tool. Including the Smoothing slider there would also prompt for further action from user. If sidebar or the Tool tab is not open, most of the toolbar tools show no change in the viewport when selected, even mouse cursor stays the same cross.
I see this behaviour in all 2.8x builds though.
Some new info...
I tried with new nightly (blender-2.82-f1ac64921b49-linux-glibc217-x86_64), same failure.
I then tried removing all in $HOME/.config/blender/2.82, same failure.
Then I tried setting a shortcut via menu [Vertex/Smoth vertices] , Failed with similar UI glitch, no shortcut.
Tried setting shortcut via context-menu (rightclick in edit), shortcut registers but same fail...
Then I tried the same with Smoot Laplacian, works flawlessly, including all ways to invoke and setting shortcut!
I also noticed laplacian is not present in menu [Vertex/...] or the - [x] menu.
The - [x] menu has Smooth vertices grouped with Randomize (?) and randomize fail like Smooth vertices.
/ZPU
Can confirm failure of setting shortcut for Smooth Vertices from Vertex menu.
Setting a shortcut from RMB menu and using it requires a mouse click or drag to bring up the tool options, where initial value tends to be 10 and subsequent mouse movement does not reduce it so the result is distortion. Interestingly, a single click of the mouse on the viewport does not actually apply the smoothing but then touching the tool options updates the mesh.
Added subscriber: @lichtwerk
Can confirm calling
Smooth Vertices
from a shortcut behaves differently from 2.81 release, will check on this further... (this somehow seems to try to call the tool and not the operator?...)Using the toolbar [aka "the - [x] menu"] and clicking on the tool there seems to work fine here though?
(not sure I am missing something from the repro steps, please clarify the failure in the toolbar...)
And please only one issue per report, answers below, but these will be ignored from now on [unless this is really connected to the reported issue...]
Do you have the tool settings visible?
True, but not a bug
Smooth vertices in edit mode stopped working (works in 2.81)to Smooth vertices called from a shortcut behaves differently in 2.82 [compared to 2.81 release]Added subscriber: @ideasman42
Caused by
f4a4ec8425
@ideasman42 : can these still be called with
EXEC_DEFAULT
from a shortcut? Or properly start the modal? (seem to be stuck in the middle and waiting for the mouse click...)Added subscriber: @ThatAsherGuy
Added subscriber: @WilliamReynish
I cannot reproduce any issues with the Smooth tool here. Seems to work normally.
I can still reproduce this with e.g.
f1ac64921b
.But this is working fine in todays build.
Havent hunted down the exact commit, but looks like this was resolved along the way, closing...
@JonasPrintzen: please try a new build from https://builder.blender.org/download/
(feel free to comment again if issues persist...)
The core issue still exists; call the operator via operator search. If you want a superficial fix, do this:
For a more thorough fix you'll have call
ED_workspace_status_text()
inop_generic_value_invoke()
and throw some info into the status bar, so users know they're in a modal, and base the adjustment amount on the initializing click location instead of where the cursor was on invoke.Changed status from 'Resolved' to: 'Needs Developer To Reproduce'
Thx for getting back, will have a look again
I see this was (partially) addressed in
86832ececc
.So thats why I wasnt able reproduce when calling from the menus (or thus shortcuts) because these are now calling the operator with a factor set, immediately executing.
True though that calling this from the F3 search will still leave you stuck in modal...
@ideasman42 : will lower the prio (and update the task description), but have an idea here?
Smooth vertices called from a shortcut behaves differently in 2.82 [compared to 2.81 release]to Smooth Vertices called from the F3 operator search will put you in a modal without knowing [doesnt execute immediately]Added subscriber: @OdinFernandezMoreno
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
Smooth is now a modal operator, calling from operator-search gives similar behavior to inset and bevel.
If you want to access this non-modally, it can be done via the vertex menu (
Ctrl-V, O
for example), or you can assign this menu item to a key binding which also runs non-modally.Closing.
The issue is that, when 'wait for input' is true (as it is by default), the modal starts without updating the header or the status bar. The user doesn't know a modal has started, why viewport navigation is blocked, or what input the operator is waiting for. When they do figure it out, the modal starts with an arbitrary smooth value that's rarely useful.
Is that the intended behavior?
Added subscriber: @AnadinX
@ideasman42 (sorry to raise this on a closed issue but I agree with @ThatAsherGuy. If you look in the attached video, (from 2.8 Beta)
bevel puts you into a state (there is a line between the cursor and the object, moving the mouse has an obvious function
inset puts you into a state (there is a line between the cursor and the object, moving the mouse has an obvious function
smooth does absolutely nothing, no change on any status bars, no in view indicator etc. You HAVE to click on the screen to make the info/interaction window even appear.
In Blender 2.79, the panel appears in the T-Panel when you invoke the operator from the search menu,
BevelInsertSmooth.mp4
PS Extude is also intuitive, your mouse movement extrudes the face, there is no extra click to enable/start the operator.
@ThatAsherGuy's point is you are put into a state where you really don't know what is going on.
If you choose Smooth from the search menu you get nothing on screen at all
If you choose Smooth from the context menu, you get the popup with the values etc. but no widget
if you choose Smooth from the tool bar you get a widget but no popup, that popup suddenly appears once you start interacting with the widget
At the very least when choosing it from the search menu the popup showing would at least let you know you are able/about to do something
