dissolve edges and then uncheck dissolve verts no undo problem
Open, Needs Information from UserPublic
Graphics card: Intel(R) HD Graphics 630 Intel 4.5.0 - Build 26.20.100.7000
Broken: version: 2.82 (sub 3), branch: master, commit date: 2019-11-30 17:33, hash: rBf1ac64921b49
[if vertex and edge select mode are checked, doing |Ctrl X| on selected edges and then unchecking dissolve verts option, deleted vertices are not reappearing]
-- (zgorg) renamed this task from disolve edges and disolve verts option undo to dissolve edges and then uncheck dissolve verts no undo problem.Sun, Dec 1, 8:12 PM
-- (zgorg) created this task.
-- (zgorg) updated the task description. (Show Details)
-- (zgorg) updated the task description. (Show Details)Sun, Dec 1, 8:15 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Tue, Dec 3, 11:35 AM
Not 100% sure, but unchecking this option is not supposed to mean the operator is doing nothing.
Dissolve remaining verts is what this is about.
Also I dont see this tied to the situation of "vertex and edge select mode are both checked" isnt it the same for edge select mode only / vert select mode only?
To further progress with this report, it would be good to share an example .blend file where you clearly show if this is different for the particular select modes, what would be expected, and what the faulty behavior is...
