Wireframe overlay still visible after turning it off
Operating system: Linux-5.3.11-1-MANJARO-x86_64-with-arch-Manjaro-Linux 64 Bits
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.82 (sub 3), branch: master, commit date: 2019-12-02 18:02, hash: rB1e480840a212
Worked: 2.82 (sub 1), branch: master, commit date: 2019-11-17 21:26, hash: 6d9d24e3d459, type: Release
Worked: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash: 26bd5ebd42e3, type: Release
Note: 2.82.3 was compiled by me, so hopefully this isn't the issue. I will test with a fresh download from the Blender website later.
Wireframe overlay is still visible after turning it off, after entering and exiting edit mode.
  1. File > Defaults > Load Factory Settings
  2. In the top right of the 3D viewport, click the Overlay drop down panel and enable Wireframe
  3. Press Tab to enter edit mode
  4. Press Tab to exit edit mode
  5. In the top right of the 3D viewport, click the Overlay drop down panel and disable Wireframe
  6. Deselect the object (Alt-a)
After doing this, the wireframe is still visible. Adding a new object or duplicating the cube will (correctly) result in an object without wireframe, while the original cube will still show it.
i have this bug all the time when wireframe is staying and u have to go to object mode >> edit mode >> object mode and it disapears.. however it is still visible on all other objects so u have to go every single one or just restart blender. i had it on 2.81 official
ubunu 18.04 LTS
Jeroen Bakker (jbakker) lowered the priority of this task from Needs Triage by Developer to Confirmed, High.
Thanks for the report, we have refactoring this part last week, so it can be that some of these regressions happen.
Ok, issue seems to be that ibo.lines is filled so isn't requested. As it isn't requested the ibo contains all lines.
my solution would be to add a separate ibo.loose_lines that will be constructed of the existing ibo.lines.
This will keep the performance the same as we currently have, but might need an architectural exception as we construct an ibo based on another ibo.
Will first test if this will work....
