Rendering crashes cycles on a specific tile with segfault #72151
Closed
opened 2019-12-03 21:04:07 +01:00 by François Cerbelle · 16 comments
Operating system: Debian buster linux
Graphics card: none
Reproduced on several computers
Broken:
Open attached, should already be on scene 05/frame 405 with selected region, press F12
Thanks
**System Information** Operating system: Debian buster linux Graphics card: none Reproduced on several computers **Blender Version** Broken: - v2.80 official - v2.82 Alpha 2019-12-03 15:16 b81939716de8 [Redis06-DataScalability_v3.blend](https://archive.blender.org/developer/F8187840/Redis06-DataScalability_v3.blend) Crash on scene 05, frame 405 (faulty region selected in attached file), frame 450 Open attached, should already be on scene 05/frame 405 with selected region, press F12 Thanks
Added subscriber: @Fanfan
Added subscriber: @mano-wii
I can't reproduce the problem.
Rendered without crashing here.
Operating system: Windows-10-10.0.18941 64 Bits
Maybe the crash occurs only on Linux?
I can't reproduce the problem. Rendered without crashing here. **Operating system:** Windows-10-10.0.18941 64 Bits Maybe the crash occurs only on Linux?
Hi,
I don't have any non-linux machine to test. But, for sure, thecrash
occured always in the selected render region only (not before, at least)
If it can help, my machines are both i7 4cores/8Threads, using
auto-detect threads and auto-tile add-on.
Thank you
Regards
François
Hi, I don't have any non-linux machine to test. But, for sure, thecrash occured always in the selected render region only (not before, at least) If it can help, my machines are both i7 4cores/8Threads, using auto-detect threads and auto-tile add-on. Thank you Regards François
Added subscriber: @Macroni
its crashing for me,on linux (ubuntu 18.10),with blender 2.81.
The scene is exceeding a fixed max limit BVH_OSTACK_SIZE = 768
causing assert failure 'kernel_assert(stack_ptr < BVH_OSTACK_SIZE);'
  • 0 __GI_raise() at /build/glibc-B9XfQf/glibc-2.28/sysdeps/unix/sysv/linux/raise.c:50
  • 1 __GI_abort() at /build/glibc-B9XfQf/glibc-2.28/stdlib/abort.c:79
  • 2 __assert_fail_base() at /build/glibc-B9XfQf/glibc-2.28/assert/assert.c:92
  • 3 __GI___assert_fail() at /build/glibc-B9XfQf/glibc-2.28/assert/assert.c:101
  • 4 ccl::OBVH_bvh_intersect_motion() at /home/stuff6/blender/git/blender/intern/cycles/kernel/bvh/obvh_traversal.h:249
  • 5 ccl::bvh_intersect_motion() at /home/stuff6/blender/git/blender/intern/cycles/kernel/bvh/bvh_traversal.h:348
  • 6 ccl::scene_intersect() at /home/stuff6/blender/git/blender/intern/cycles/kernel/bvh/bvh.h:257
  • 7 ccl::kernel_path_scene_intersect() at /home/stuff6/blender/git/blender/intern/cycles/kernel/kernel_path.h:68
  • 8 ccl::kernel_path_integrate() at /home/stuff6/blender/git/blender/intern/cycles/kernel/kernel_path.h:539
  • 9 ccl::kernel_path_trace() at /home/stuff6/blender/git/blender/intern/cycles/kernel/kernel_path.h:692
  • 10 ccl::kernel_cpu_avx2_path_trace() at /home/stuff6/blender/git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_impl.h:90
  • 11 ccl::CPUDevice::path_trace() at /home/stuff6/blender/git/blender/intern/cycles/device/device_cpu.cpp:851
  • 12 ccl::CPUDevice::thread_render() at /home/stuff6/blender/git/blender/intern/cycles/device/device_cpu.cpp:933
  • 13 ccl::CPUDevice::thread_run() at /home/stuff6/blender/git/blender/intern/cycles/device/device_cpu.cpp:512
  • 14 std::__invoke_impl<void, void (ccl::CPUDevice::&)(ccl::DeviceTask), ccl::CPUDevice*&, ccl::CPUDevice::CPUDeviceTask*&>() at /usr/include/c++/7/bits/invoke.h:73
  • 15 std::__invoke<void (ccl::CPUDevice::&)(ccl::DeviceTask), ccl::CPUDevice*&, ccl::CPUDevice::CPUDeviceTask*&>() at /usr/include/c++/7/bits/invoke.h:95
  • 16 std::_Bind<void (ccl::CPUDevice::(ccl::CPUDevice, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)>::__call<void, int&&, 0ul, 1ul>(std::tuple<int&&>&&, std::_Index_tuple<0ul, 1ul>)() at /usr/include/c++/7/functional:467
  • 17 std::_Bind<void (ccl::CPUDevice::(ccl::CPUDevice, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)>::operator()<int, void>(int&&)() at /usr/include/c++/7/functional:551
  • 18 std::_Function_handler<void (int), std::_Bind<void (ccl::CPUDevice::(ccl::CPUDevice, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)> >::_M_invoke(std::_Any_data const&, int&&)() at /usr/include/c++/7/bits/std_function.h:316
  • 19 std::function<void (int)>::operator()(int) const() at /usr/include/c++/7/bits/std_function.h:706
20 ccl::TaskScheduler::thread_run() at /home/stuff6/blender/git/blender/intern/cycles/util/util_task.cpp:396
its crashing for me,on linux (ubuntu 18.10),with blender 2.81. The scene is exceeding a fixed max limit BVH_OSTACK_SIZE = 768 causing assert failure 'kernel_assert(stack_ptr < BVH_OSTACK_SIZE);' - 0 __GI_raise() at /build/glibc-B9XfQf/glibc-2.28/sysdeps/unix/sysv/linux/raise.c:50 - 1 __GI_abort() at /build/glibc-B9XfQf/glibc-2.28/stdlib/abort.c:79 - 2 __assert_fail_base() at /build/glibc-B9XfQf/glibc-2.28/assert/assert.c:92 - 3 __GI___assert_fail() at /build/glibc-B9XfQf/glibc-2.28/assert/assert.c:101 - 4 ccl::OBVH_bvh_intersect_motion() at /home/stuff6/blender/git/blender/intern/cycles/kernel/bvh/obvh_traversal.h:249 - 5 ccl::bvh_intersect_motion() at /home/stuff6/blender/git/blender/intern/cycles/kernel/bvh/bvh_traversal.h:348 - 6 ccl::scene_intersect() at /home/stuff6/blender/git/blender/intern/cycles/kernel/bvh/bvh.h:257 - 7 ccl::kernel_path_scene_intersect() at /home/stuff6/blender/git/blender/intern/cycles/kernel/kernel_path.h:68 - 8 ccl::kernel_path_integrate() at /home/stuff6/blender/git/blender/intern/cycles/kernel/kernel_path.h:539 - 9 ccl::kernel_path_trace() at /home/stuff6/blender/git/blender/intern/cycles/kernel/kernel_path.h:692 - 10 ccl::kernel_cpu_avx2_path_trace() at /home/stuff6/blender/git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_impl.h:90 - 11 ccl::CPUDevice::path_trace() at /home/stuff6/blender/git/blender/intern/cycles/device/device_cpu.cpp:851 - 12 ccl::CPUDevice::thread_render() at /home/stuff6/blender/git/blender/intern/cycles/device/device_cpu.cpp:933 - 13 ccl::CPUDevice::thread_run() at /home/stuff6/blender/git/blender/intern/cycles/device/device_cpu.cpp:512 - 14 std::__invoke_impl<void, void (ccl::CPUDevice::*&)(ccl::DeviceTask*), ccl::CPUDevice*&, ccl::CPUDevice::CPUDeviceTask*&>() at /usr/include/c++/7/bits/invoke.h:73 - 15 std::__invoke<void (ccl::CPUDevice::*&)(ccl::DeviceTask*), ccl::CPUDevice*&, ccl::CPUDevice::CPUDeviceTask*&>() at /usr/include/c++/7/bits/invoke.h:95 - 16 std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)>::__call<void, int&&, 0ul, 1ul>(std::tuple<int&&>&&, std::_Index_tuple<0ul, 1ul>)() at /usr/include/c++/7/functional:467 - 17 std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)>::operator()<int, void>(int&&)() at /usr/include/c++/7/functional:551 - 18 std::_Function_handler<void (int), std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)> >::_M_invoke(std::_Any_data const&, int&&)() at /usr/include/c++/7/bits/std_function.h:316 - 19 std::function<void (int)>::operator()(int) const() at /usr/include/c++/7/bits/std_function.h:706 # 20 ccl::TaskScheduler::thread_run() at /home/stuff6/blender/git/blender/intern/cycles/util/util_task.cpp:396
i was able to render the full scene by subdividing the green ground plane mesh into 4x4 quads.
i thnk the bvh tree is crapping out because there is too many faces at one location + 1 larrge quad or something.
i was able to render the full scene by subdividing the green ground plane mesh into 4x4 quads. i thnk the bvh tree is crapping out because there is too many faces at one location + 1 larrge quad or something.
Member
Member
Member
I had it crashing once, but I think that was for an unrelated reason, and I also cannot reproduce it anymore.
@Macroni can you reproduce that crash reliably or does it only happen sometimes?
@Fanfan At one point you wrote frame 450 in your initial post, is that a typo?
I had it crashing once, but I think that was for an unrelated reason, and I also cannot reproduce it anymore. @Macroni can you reproduce that crash reliably or does it only happen sometimes? @Fanfan At one point you wrote `frame 450` in your initial post, is that a typo?
@JacquesLucke No, not a typo, It crashed also on this frame.
I don't have the laptop on which I discovered this crash anymore, I have a brand new computer, reinstalled from scratch, with Blender 2.80. I downloaded the attached file, opened it and pressed F12. It crashed. immediately (Scene 5, Frame 405, selected area). I tried to reopen, moved to scene 5, frame 450, removed the render area selection and pressed F12 : crash somewhere below the book in bookshelf "Le Misanthrope"
@JacquesLucke No, not a typo, It crashed also on this frame. I don't have the laptop on which I discovered this crash anymore, I have a brand new computer, reinstalled from scratch, with Blender 2.80. I downloaded the attached file, opened it and pressed F12. It crashed. immediately (Scene 5, Frame 405, selected area). I tried to reopen, moved to scene 5, frame 450, removed the render area selection and pressed F12 : crash somewhere below the book in bookshelf "Le Misanthrope"
Member
Crashes everytime for me on linux with 2.81a.
Splitting the single face of mesh 'Plane.000' into 4 quads fixes it for me.
However , blender-2.82-3e11c4e63b2f-linux-glibc217-x86_64 downloaded from https://builder.blender.org/download/
works fine.so maybe the bug is fixed in blender-2.82-3e11c4e63b2f
Crashes everytime for me on linux with 2.81a. Splitting the single face of mesh 'Plane.000' into 4 quads fixes it for me. However , blender-2.82-3e11c4e63b2f-linux-glibc217-x86_64 downloaded from https://builder.blender.org/download/ works fine.so maybe the bug is fixed in blender-2.82-3e11c4e63b2f
Member
Added subscriber: @lichtwerk
Member
Philipp Oeser self-assigned this 2020-01-21 15:17:55 +01:00
Member
Can reliably make it crash in 2.81a as well, but current master or current builbot builds are fine...
(not aware of any specific commit that changed there, or if some default changed, but will assume this is resolved for good...)
@Fanfan , @Macroni : feel free to comment again if this creeps up another time...
Can reliably make it crash in 2.81a as well, but current master or current builbot builds are fine... (not aware of any specific commit that changed there, or if some default changed, but will assume this is resolved for good...) @Fanfan , @Macroni : feel free to comment again if this creeps up another time...
5 Participants
Reference: blender/blender#72151
