Copy Rotation Constraint - influence calculation incorrect #72323
2 Participants
Reference: blender/blender#72323
Operating system: Windows 7 Pro 64-Bit
Graphics card: NVidia GeForce GTX 1060 6GB
Broken: 2.81a and 2.79b
Worked:
When using the Copy Rotation constraint, if the influence is set to less than one ( 1.00 ) the calculated result(s) jump around; sometimes flipped 180° across the rotational axis, sometimes just jumping to other rotational positional offsets, depending upon the influence percentage setting.
This happens on all axis (X, Y and Z) and seems to occur at any influence value less than 1.00
Calculation algorithm of 'influence' factor evidently faulty
Create object - Note: object must not be of uniform or mirrored shape across axis or rotational calculation fault will not be evident
Duplicate object and move away from first object.
Animate first object - in this case simple rotations on Z axis.
Select second object and apply Copy Rotation constraint with first object as target - set influence to 0.5
Second object's rotational position will be seen to be flipping occasionally with respect to position of target object when animation running.
Please see attached blend file: constraint _influence_bug.blend
Added subscriber: @ignatz
Added subscriber: @mano-wii
Known limitation. See #32917
Closed as duplicate of #32917
