Texture paint - sample color picker is highly unreliable when "clip end" distances are large enough #72372
Closed
opened 2019-12-12 03:46:47 +01:00 by Vas · 6 comments
Operating system: Windows-10-10.0.17763-SP0 64 Bits
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66
Broken: version: 2.82 (sub 4), branch: master, commit date: 2019-12-10 23:56, hash: 63d521432e
I'm not sure if this is a bug or a system limitation, but after couple of hours prodding I can conclude this:
  • If clip end is 100m-1000m and camera lens is <100mm , Texture paint sample color is accuare and reliable
  • If clip end is 1000m-6000m and camera lens is 35-200mm, when you zoom in and start sampling color, there's a small chance of wrong color picking (sampling merged colors instead of original texture source)
  • if clip end is >10000m and there's any kind of zoom in, the color picking becomes 50/50 chance to actually sample the texture source, basically impossible to pick the right color
This can be a pretty big issue for someone who works on big scenes and paints textures (like roughness maps/normal maps) in blender, You naturally tend to zoom in a lot to have a better stroke/precision, but zooming in viewport causes a huge decreasce in sampling accuracy. I found out the cause and managed to metigate it by decreascing Clip End distance of some cameras. And in the example below, 1000m is not even that much for a clip end distance.
Here's a clip demonstrating what I mean:
2019-12-12 02-01-48.mp4
In the source file I demonstrated the minumum clip end + viewport zoom necessary to casue this instability, the main culprid of this is the Clip End + Viewport zoom in values. If Clip End is anything like 10000m then it becomes practically unusable to sample colors
Also this effect is a lot more proiminent on the edges of the mesh
  • Open the blend file
  • Enable the Render view
  • make sure the cyan texture is selected in shader editor (bad big.png)
  • Enter the camera view
  • go to 3D view and enter the Texture Paint mode
  • Press S to sample the colors (less reliable on edges of mesh
  • Zoom in and notice that sampling becomes even less accurate
sample color bug 2.blend
**System Information** Operating system: Windows-10-10.0.17763-SP0 64 Bits Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66 **Blender Version** Broken: version: 2.82 (sub 4), branch: master, commit date: 2019-12-10 23:56, hash: `63d521432e` Worked: (optional) **Short description of error** I'm not sure if this is a bug or a system limitation, but after couple of hours prodding I can conclude this: - If clip end is 100m-1000m and camera lens is <100mm , Texture paint sample color is accuare and reliable - If clip end is 1000m-6000m and camera lens is 35-200mm, when you zoom in and start sampling color, there's a small chance of wrong color picking (sampling merged colors instead of original texture source) - if clip end is >10000m and there's any kind of zoom in, the color picking becomes 50/50 chance to actually sample the texture source, basically impossible to pick the right color This can be a pretty big issue for someone who works on big scenes and paints textures (like roughness maps/normal maps) in blender, You naturally tend to zoom in a lot to have a better stroke/precision, but zooming in viewport causes a huge decreasce in sampling accuracy. I found out the cause and managed to metigate it by decreascing Clip End distance of some cameras. And in the example below, 1000m is not even that much for a clip end distance. Here's a clip demonstrating what I mean: [2019-12-12 02-01-48.mp4](https://archive.blender.org/developer/F8210974/2019-12-12_02-01-48.mp4) In the source file I demonstrated the minumum clip end + viewport zoom necessary to casue this instability, the main culprid of this is the Clip End + Viewport zoom in values. If Clip End is anything like 10000m then it becomes practically unusable to sample colors Also this effect is a lot more proiminent on the edges of the mesh **Exact steps for others to reproduce the error** [Please describe the exact steps needed to reproduce the issue] - Open the blend file - Enable the Render view - make sure the cyan texture is selected in shader editor (bad big.png) - Enter the camera view - go to 3D view and enter the Texture Paint mode - Press S to sample the colors (less reliable on edges of mesh - Zoom in and notice that sampling becomes even less accurate [sample color bug 2.blend](https://archive.blender.org/developer/F8211013/sample_color_bug_2.blend)
Author
Added subscriber: @Alumx
Added subscriber: @mano-wii
Dev note:
I suspect this is a raycast inaccuracy due to the distance from ray_start.
If so, a solution would be to move ray_start to the point where it hits bound_box.
Dev note: I suspect this is a raycast inaccuracy due to the distance from ray_start. If so, a solution would be to move ray_start to the point where it hits bound_box.
Germano Cavalcante self-assigned this 2019-12-17 19:06:48 +01:00
After investigating, I realized that it has nothing to do with raycast, but with select_engine.
This issue was referenced by 61f4a7d1f5
This issue was referenced by 61f4a7d1f593e3870e7a0df4b32e95516b236eef
Reference: blender/blender#72372
