Bevel Custom Profile: no way to Copy To Selected #72422
6 Participants
Reference: blender/blender#72422
Broken: 2.82 (
322555faa3
)Short description of error
Unlike other properties, the new Bevel Profile widget doesn't seem to allow to Copy To Selected. One can only ctrl+c/ctrl+v the curve individually, but there doesn't appear to be a way to do it en masse. Right-clicking the widget only produces the area context menu.
Furthermore, it doesn't appear that the widget allows multi-editing (i.e. with alt key pressed), which most of the other properties, including modifier properties, allow to do.
Video demonstration for clarity:
https://youtu.be/_kLiG6iatXQ
Added subscriber: @Stan_Pancakes
Bevel Profile: no way to Copy To Selectedto Bevel Custom Profile: no way to Copy To SelectedAdded subscriber: @JacquesLucke
I can confirm that this is a missing feature. However, I'm closing this because it is not a bug. For feature requests you can use https://blender.community/c/rightclickselect/.
I'm sorry, was that new property intended to not work as other properties? Please just forward this to @HooglyBoogly, I really can't see how this is a "feature request", let alone needing to go through RCS.
The issue is that there are thousands of open bug reports so it's important to make it clear that the bug tracker is just for bugs (code that was intended to work but doesn't).
Indeed I didn't think of adding this in the summer or the fall. If I get some time I'll look into it, I agree it would be nice to have.
Not counting common modifier properties (visibility/renderability), there are 18 properties on the Bevel modifier that support Copy to Selected, including the 'Custom Profile' checkbox itself, yet the profile widget does not support it. In my book, it sure looks like it was "intended" for properties to be copyable.
This is not the way to reduce the thousands of open bug reports, this invites more reports down the line that would need to be triaged and rejected, with something along the lines of "unfortunately, this is a known limitation, blah blah". @JacquesLucke could've (and should've) put this one down as a "to do". Please don't tell people to go to a third party resource to "request" Blender to conform to its own functionality.
Well, I'm sorry that it works this way. I do agree that this is useful und missing functionality. However, to be able to keep things under control, we have rules for the bug tracker. You can read more about how bug reports are handled here:
https://wiki.blender.org/wiki/Process/Bug_Reports/Triaging_Playbook
This issue is an "accidental feature request".
This is not a feature request, and it most certainly is not accidental. So, since this is not a bug, and the widget behaves as intended, it follows that Copy To Selected functionality was never intended to be provided by this widget, and right-clicking was instead intended to simply show area context menu. Is that correct?
Added subscriber: @scorpion81
Hmm, seems this is no simple oneliner in order to fix this issue.
After some search in the code and some debugging, i found out that here
https://developer.blender.org/diffusion/B/browse/master/source/blender/editors/interface/interface_context_menu.c$543
but->rnapoin.data && but->rnaprop seem not to be set (if you rightclick on the curve in the bevel modifier).
The curve is defined here basically
https://developer.blender.org/diffusion/B/browse/master/source/blender/editors/interface/interface_templates.c$4959
but there is no uiBut (no button) inside the curve area itself one could bind the context menu entries to. Its just an uiBlock, which works differently.
The rnapoin and rnaprop data is handled by a callback here, RNAUpdateCb.
Bottom line, it seems (for me atleast, who is unfamiliar to that code area) not so super easy to fix this properly.
Maybe one would need to write a custom (mass) copy operator which iterates over the curve points / handles or so. But i dont think those are exposed via python,
so this needs to be done in C.
Edit: the points of the custom profile are exposed to python. You can add some via a script. But unfortunately, the curve does not update (argh, only after you move one of the points, and chances are you get a messed up curve then)
script example:
@scorpion81 Thanks for looking into this! In general the Python API for the
CurveProfile
might not have the best UX. If there are any improvements I can make to that I'd be happy to. As a more long-term goal I'd like the widget to be useful in more places in Blender. Try adding an update call after adding a point. It doesn't do that automatically because it's a relatively more expensive operation.Copying a PM from blenderartists to here:
@Stan_Pancakes I actually do have some time in the next few days so I was going to look at looking into working on the feature you requested, but after more thought I’m not sure it makes sense to implement this like you described.
EDIT: I think I misunderstood the issue: I see what you mean now, I'll see what I can find.
Added subscriber: @EAW
Just adding that the curve widget in the Vertex Weight Edit modifier also does not have the
copy to selected
functionality, so modifiers are consistent in that respect.I was just checking to see if it did as it would have made adding the functionality to the Bevel modifier much easier.
@HooglyBoogly
Thanks, the custom_profile.update() call seems to work. But the target curve's widget looks often a bit weird afterwards, aka weird triangular artifacts.
Source Curve:
Destination Curve before copy: (has already another point added)
Destination Curve after copy:
Note: I have an Intel UHD 620 graphics chip, Windows 10, recent-ish master.
(in fact, a custom branch, bone-openvdb)
custom_profile.blend
In that blend, just make lower cube active, select upper cube, Run script.
(Not sure whether this is worthy a separate report, tho. Maybe its just related to the intel gpu / some opengl issue.)
That's a known issue with the way the fill is triangulated. When there's overlap (the profile crosses over itself) it can look pretty glitchy. In that case it would create bad geometry in the bevel anyway, and for most situations it works well, so I don't think it's a huge problem.
In your case I think it's just the automatic handle calculation that makes the path cross itself. I think you'll find if you drag the point around a bit it won't look like that.
It chooses which edge to put the new point on by finding the closest segment, but I guess if there were enough demand I could give the python API the ability to choose an index.
Just for minimizing confusion, video added.
Tried to patch this, but the more I dig into it, the more questions arise, lol...
For example what on earth has "Overrides" to do with copying something on RNA level ? Is that the same as Static / Dynamic Override (which never was finished up to now) or something different with the same name ?
Lol... Anyways, I will share here my partially working patch, but it wont copy the Custom Profile, just re-assign it to the other modifier. Probably this is some corner case with Pointer Properties, which are not meant to be copied but to be assigned somewhere else only. But this doesnt work here. In case one of the other bevel modifier objects is deleted, blender will crash.
Probably, in order to make the CurveProfile more re-usable and copy-able (in one go) , it must become some separate ID which can be linked into the bevel modifier, like a cachefile is linked into the Meshcachesequence modifier or Particle Settings are being linked into a Particle System Modifier.
attempt_for_copy_to_selected_curve_profile.diff
Added subscriber: @Sparazza
