Assert Dragging & dropping color in the Image Editor (double UNDO push?)
Closed, ResolvedPublicBUG
Operating system: Linux-5.3.12-200.fc30.x86_64-x86_64-with-fedora-30-Thirty 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.31
Broken: version: 2.82 (sub 5), branch: master, commit date: 2019-12-16 11:41, hash: rBbbc97fc533d0
Assert Dragging & dropping color in the Image Editor from the color button onto the image.
(also reported in T72440, but that crash was fixed...)
  • Open file
  • Drag white color from the color button in the tool settings onto the image
  • Assert
BLI_assert failed: /blender/source/blender/blenkernel/intern/undo_system.c:457, BKE_undosys_step_push_init_with_type(), at 'ustack->step_init == ((void *)0)'
ustack->step_init is not NULL (already has Drop Color, wants to do for ED_imapaint_bucket_fill as well, so seems like two undo pushes where only one is allowed?)
1  raise                                                       0x7ffff1ae4e35
2  abort                                                       0x7ffff1acf895
3  BKE_undosys_step_push_init_with_type undo_system.c     457  0x3f9fdeb
4  image_undo_push_begin                image_undo.c      1017 0x3e95f0f
5  ED_image_undo_push_begin             image_undo.c      1026 0x3e95fa9
6  ED_imapaint_bucket_fill              paint_image.c     1308 0x3b5edcf
7  drop_color_invoke                    interface_ops.c   1700 0x3d67d3c
8  wm_operator_invoke                   wm_event_system.c 1441 0x32e9559
9  wm_operator_call_internal            wm_event_system.c 1688 0x32e9e5c
10 wm_handlers_do_intern                wm_event_system.c 2773 0x32eca78
11 wm_handlers_do                       wm_event_system.c 2993 0x32ed5a2
12 wm_event_do_handlers                 wm_event_system.c 3480 0x32eebf6
13 WM_main                              wm.c              417  0x32e1ba2
14 main                                 creator.c         496  0x2d17ef6
Sybren A. Stüvel (sybren) changed the subtype of this task from "Report" to "Bug".Jan 20 2020, 1:57 PM
There are actually two issues with ED_imapaint_bucket_fill(), the undo and the call to paint_2d_bucket_fill().
The undo breaks because ED_imapaint_bucket_fill() calls BKE_undosys_step_push_init_with_type() and ED_image_undo_push_begin() which also tries to initialize the undo step with BKE_undosys_step_push_init_with_type(). Removing the BKE_undosys_step_push_init_with_type() in ED_imapaint_bucket_fill() would fix this problem. I'm not very familiar with the undo system, but the BKE_undosys_step_push() could probably be replaced with ED_image_undo_push_end().
The call to paint_2d_bucket_fill() has the last argument set to NULL which results in a NULL pointer dereferencing. The strength should therefore be set to 1.0f by default and only retrieve the brush alpha when both the pointer to the brush and the image paint state aren't NULL.
