Switching collections does not work in Local mode. #72520
7 Participants
Reference: blender/blender#72520
Graphics card: GeForce GTX 580/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
Broken: version: 2.82 (sub 5), branch: master, commit date: 2019-12-17 03:33, hash:
8676491090
Worked: 2.81
In Local mode, switching collections with hotkeys (1, 2, 3 ...) does not work.
When I select several objects from different collections, and go into local mode, switching collections through hot keys (1, 2, 3, etc.) stops working.
Added subscriber: @AndreyRusnak
Added subscribers: @dfelinto, @lichtwerk
@dfelinto: should this always be working on top of local view (still a bit confused by the design here as well...)?
couple of notes:
Local Collections
turned ON for this viewport [including using shortcuts](would have assumed this is decoupled and local view always has precedence over collection visibility -- 2.79 also didnt account for layer visibility in local view iirc, but since this is working with
Local Collections
... will let @dfelinto decide...)Added subscriber: @EitanSomething
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Is this still an issue with 2.83?
Added subscriber: @ideasman42
Yes, although this is more a design topic, we could disallow switching collections in Local Mode.
@dfelinto what do you think?
Added subscriber: @eyecandy
I think we should disallow, but I would rather hear from someone like @eyecandy . I will ask him about that.
Let me elaborate a bit further. I think local view and (local or not) collections should be separated, to reduce the mental burden to the user. Local view = a quick way to isolated the objects you have, highly toggleable. For everything more permanent, or that needs to last an entire working session, use collections.
I agree with @dfelinto, the local view is meant to isolate objects quickly. It's not even using the same visibility feedback system (the eye icons in the outliner), so it should take priority and not allow collection visibility switching.
i'm all for making local view more distinct from regular viewport to make it clear what the user can and can not do, maybe by dimming the background color? just an idea...
Andy
Even so, collections continue to switch in isolation mode at this time. However, this is not displayed on the screen and this leads to a number of problems.
However, by eliminating this feature (which was present in previous versions), you remove the ability to quickly and conveniently do retopology of different parts of the complex model (for example, a character with a body kit).
Which is very important for game dev.
Imagine a situation when we have a lot of high-poly objects in one collection, and a lot of low-poly retopo models are created in another collection.
Previously, I took highpoly and lowpoly elements, turned on isolation mode and I could switch between them quickly and easily, to do retopology using the numbers 1, 2, for example.
Then I went out of isolation mode, chose a jacket / hat / head, went into isolation mode again. And so on, with dozens and hundreds of other objects.
This allows you to quickly make changes to the low poly at any stage, for any element of the complex model. It allows to compare how much the low poly shape repeats the high poly and where there is not enough geometry.
You can switch between HP and LP of the entire model, or you can switch between several objects without dragging them into the collection.
Now do you offer to take it out to separate collections each time?
The blender is still lacking game development tools. Retopo is no exception. Despite this, I have been doing retopology in a blender for many years. Do not break the usual tools.
Or give us a convenient alternative. Oh please :)
Added subscriber: @Imaginer
