Weight Painting intermittent issues with brush, not adding or subtracting weight, not influencing correct areas #72524
Reference: blender/blender#72524
Operating system: Windows 10 Pro
Graphics card: RTX 2080ti + 3x GTX 1080Ti - Running 4 monitors and a pen tablet at three different resolutions using outputs from two GPUs (4k, 1440p, 1080p)
Broken: 2.81 stable
Worked: 2.80
I have had numerous issues with weight painting in 2.81, however duplicating them has been problematic as this crops up intermittently. In this example, I saved this working file right at the moment I started having problems. Here I can neither add nor subtract weight with the brush in Weight paint mode from a certain distance from the model.
In other instances, I've had issues with the brush not painting over the vertices it's over. I use a hard falloff brush, so anything inside the circle gets painted, anything outside gets nothing. Essentially, it acts like the circle where the brush is being displayed, is not where the circle actually is, if that makes sense.
I tried exporting this to it's own file, but that seems to fix it. It has to be in the full working file I'll provide here. You should hopefully be able to open the file, already be in weight painting mode, with the brush set up, over some masked vertices ready to add or subtract. Try switching the brush to add, and zoomed in fairly close, add some weight, and nothing happens. However, zoom out and do the same thing, and watch weight be added.
You can kind of jump around and try rigging other parts of the car, I've been having issues with it off and on for the past few days.
70sNewYorkers.blend
Added subscriber: @HardRooster
Added subscriber: @mano-wii
I don't know if I get it right, but I believe this issue is related to the same issue described in #70128
#72121 is a variant of the same problem.
I reproduced this bug in the latest official release, but not the latest daily build, so it appears the bug has been fixed already :)
Please try the latest daily build: https://builder.blender.org/download/
If the problem persists, please let us know so we can re-open the report. Don't forget to mention the specific version you tested again.
Added subscriber: @lichtwerk
Changed status from 'Resolved' to: 'Confirmed'
I can still reproduce this.
Operating system: Linux-5.3.12-200.fc30.x86_64-x86_64-with-fedora-30-Thirty 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.31
Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-27 20:38, hash:
c2a37867f2
Investigating again, although the recent build indicated does not work well (2.82 sub 6), it works much better than the 2.81.
I will continue investigating to see if I find something...
Did a fix get added to 2.81a? I downloaded that and at first glance things seem to be working. I have a new project to work on, I'll likely get into weight painting it tomorrow so I can report back how that works, and if it's not working right I can give the daily build a go as well and report back my findings.
The patch is being analyzed and needs some adjustments.
The problem is not that serious.
The code works as designed.
What happens is that the affected vertices are tested within a cylinder rather than a cone as expected in the perspective projection.
And this problem is only observed under very specific conditions.
