Removed Keying ability overwrites files in 2.8x #72578
Closed
opened 2019-12-19 15:34:16 +01:00 by ChristopherAnderssarian · 10 comments
Operating system: Windows 7
GPU: Radeon Vega 64, Divider version: 19.12.2
CPU: Intel Core i7-5960X
Broken: blender-2.80-f6cb5f54494e-windows64 (official release) and after
Working: blender-2.79b-f4dc9f9d68b-windows64 (official release)
One of the areas that keying has been removed from is in
Properties Editor --> Output Properties --> Output notably Overwrite.
This is troublesome as if you have disabled Overwrite for a
number of frames (in 2.79) then open in 2.8x,
this will get disregarded and the frames will be overwritten.
This can be an intermittent issue as depending on when you save in 2.79,
as the value will carry over unchanged/unchanging to 2.8x.
Open: Keying_Overwrite.blend
In 2.79b you'll see Overwrite keyed. The markers show when the keyframes are.
In 2.8x you'll see there are no keyframes for Overwrite.
Exact steps for others to reproduce the error from scratch
Try to key any of the four toggles in Output Properties.
**System Information** Operating system: Windows 7 GPU: Radeon Vega 64, Divider version: 19.12.2 CPU: Intel Core i7-5960X **Blender Version** Broken: `blender-2.80-f6cb5f54494e-windows64` (official release) and after Working: `blender-2.79b-f4dc9f9d68b-windows64` (official release) **Short description of error** One of the areas that keying has been removed from is in `Properties Editor --> Output Properties --> Output` notably Overwrite. This is troublesome as if you have disabled Overwrite for a number of frames (in 2.79) then open in 2.8x, this will get disregarded and the frames will be overwritten. This can be an intermittent issue as depending on when you save in 2.79, as the value will carry over unchanged/unchanging to 2.8x. **Exact steps for others to reproduce the error** Open: [Keying_Overwrite.blend](https://archive.blender.org/developer/F8234433/Keying_Overwrite.blend) In 2.79b you'll see Overwrite keyed. The markers show when the keyframes are. In 2.8x you'll see there are no keyframes for Overwrite. **Exact steps for others to reproduce the error from scratch** Try to key any of the four toggles in Output Properties.
Added subscriber: @ChristopherAnderssarian
Added subscriber: @mano-wii
By keying do you mean Insert a keyframe (shortcut i)?
In 2.79 this is not possible either.
Aren't you using an addon to animate these properties?
By keying do you mean Insert a keyframe (shortcut `i`)? In 2.79 this is not possible either. Aren't you using an addon to animate these properties?
Member
Added subscribers: @ideasman42, @lichtwerk
Member
@mano-wii: I can animate Overwrite in 2.79b.
This was disabled in b66ae8259e though.
@ideasman42 : not sure about the others, but for Overwrite, I can actually see this being useful?
Were there any issues with this?
@mano-wii: I can animate Overwrite in 2.79b. This was disabled in b66ae8259e though. @ideasman42 : not sure about the others, but for `Overwrite`, I can actually see this being useful? Were there any issues with this?
Added subscriber: @dr.sybren
The removal of animatibility happened in b66ae8259e without any motivation. @ideasman42 can you explain why this change happened?
@ChristopherAnderssarian you can work around this by simply keeping the 'Overwrite' checkbox unchecked, and deleting those frames you want to re-render.
The removal of animatibility happened in b66ae8259e without any motivation. @ideasman42 can you explain why this change happened? @ChristopherAnderssarian you can work around this by simply keeping the 'Overwrite' checkbox unchecked, and deleting those frames you want to re-render.
This issue was referenced by f46ba1a7e0
This issue was referenced by f46ba1a7e06d534bd93c950aed4feca87edc4fea
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
Campbell Barton self-assigned this 2019-12-23 23:08:16 +01:00
Added note on the commit for why these animation settings were removed.
Animating UI options lock-interface or display-mode aren't useful, I grouped this option in with those, while it's a little obscure, it works well so added it back.
Added note on the commit for why these animation settings were removed. Animating UI options lock-interface or display-mode aren't useful, I grouped this option in with those, while it's a little obscure, it works well so added it back.
6 Participants
Reference: blender/blender#72578
