Blender crashes using Jack with AV Sync enabled (repeatable)
Closed, ResolvedPublicBUG
Operating system: Linux-4.18.0-25-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.116
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash: rBf1aa4d18d49d
Blender crashes while scrubbing when AV Sync is enabled and system is using JACK audio
  • open blender 2.81a with fresh config dir
  • enter prefs -> System and choose JACK as audio device
  • go to VSE, add audio clip of whatever length to at least fill the default frames (I used a standard stereo 16bit PCM .wav in this case)
  • in Timeline, enable AV Sync option
  • play the animation, and scrub around with the mouse on the timeline
It takes a while of constant scrubbing for me -- sometimes 30 seconds or even 1-2 minutes, but I can reliably make Blender crash this way. (Sometimes I stop and jump around in the timeline, left/right-arrow a little, etc... not sure if any of that is necessary.) Two crash.txt's are attached.
Developer note
The issue is caused by race condition between JACK callback and dependency graph update.
One of the ideas to get it solved is to make JACK callback to act more like a tag (rahtehr than an actual action) which will allow handling it as soon as possible but not from the place where it can't be happening in a thread-safe manner.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Jan 21 2020, 3:26 PM
Can confirm in a buildbot build.
(havent built with JACK myself yet, but...confirming for now)
The crash happens as follows, when you use JACK and AV-sync, JACK transport is enabled meaning that JACK will call the sound_sync_callback, which down the road
sound_sync_callback -> sound_jack_sync_callback -> BKE_sound_jack_scene_update -> BKE_sound_play_scene -> sound_start_play_scene -> AUD_Device_play
leads to sound (in sound_start_play_scene it's scene->sound_scene) being NULL.
I figured that this is due to SceneBackup setting it so in Blender's main thread, but that's as far as I can get since I don't know what this is for. While there is a chance that sound is playing back, sound_scene should only be changed when the audio device is locked (AUD_Device_lock(sound_device); ...; AUD_Device_unlock(sound_device);), however, locking the device should be as short as possible it will cause skips, clicks, other nasty sounds, hangs, etc...
Having a callback happening from the middle of dependency graph update will never be reliable.
The proper behavior would be to do some sort of tag from the sound_jack_sync_callback which will indicate that the current frame and audio is to be updated once the event loop allows this.
Unassigning myself, it doesn't fir into my agenda. Can help with understanding the design, but can't be the one who fixes every single area.
This patch should fix the issue.
