Alembic caches are not properly updated by drivers #72660
Reference: blender/blender#72660
Operating system: Linux-5.3.12-200.fc30.x86_64-x86_64-with-fedora-30-Thirty 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.44
Broken: version: 2.83 (sub 0), branch: master, commit date: 2020-01-14 06:12, hash:
1bcb2bfd57
Alembic caches are not updated during render if the
Frame Offset
Frame is driven (works when it is keyframed )Affects both Cycles and Eevee
Note: even when both are keyframed exactly the same, I ran into the situation where a frame was not updated the same during render (and even viewport), needs investigation as well...
#72660.zip
Original report
Graphics card: Quadro P3200/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
and Blender 2.81
When rendering in eevee, there is a bug in that an alembic mesh (high density mesh) is not updating until after the render has finished.
The mesh is updating in the viewport, in both cycles and Eevee.
The mesh updates in say five-ten seconds. Eevee renders the frame (when rendering animation) in 2-3 seconds. It takes longer than eevee takes to render the frame to update the mesh, and when I render the animation, the mesh is not updating at all. So say I render frames 65-72, the renders show no change in the Alembic mesh during those frames. If I change the frame in the viewport, or render in cycles, the mesh updates and renders fine. If I set the timeline to say frame 72, then render the animation, Eevee then treats that alembic mesh as the "fixed" mesh and renders that in every frame.
one point, the mesh is updating using the position of a null to set the frame counter for the mesh, (as its start point is offset from the start of the animation - because I cannot seem to get the frame offset to work without an animation driver).
Any suggestions?
Import dense mesh as alembic sequence.
Surface it and create an animation "round" it. Offset the start time (may not be necessary). Animate the frame counter using an empty (distance in X = sequence number to display).
The mesh is really dense. It's a realflow sim with 1m + particles. I will put it on the dropbox if needed, but Blend file is here:Santa_Rigged7a.blend1
Added subscriber: @PaulHawkes
Alembic mesh Bug. Eeevee renders frame beforeb - so alembic meshto Alembic mesh Bug. Eeevee renders frame before Blender updates mesh - so alembic mesh does not update during render.Added subscriber: @lichtwerk
Yes, please put up a link so we have a chance to repro.
Hi. I have put meshes 0-85 on the dropbox. that should be sufficient. If not please let me know, and I'll put the other 3 gB up.
https://www.dropbox.com/s/5k2wi2rgm9m636j/meshes.zip?dl=0
Hm, seems to be something about the driver.
If I simply keyframe the frame offset, I get correct updates in render, with the driver I can reproduce no updates in render, checking... trying to put together something simpler (are you sure this only happens with such dense meshes?)
Added subscriber: @dr.sybren
Can only repro with the bigger .abcs (might also be about the fact that these are sequences), will update report description as well
#72660.zip
CC @dr.sybren
Alembic mesh Bug. Eeevee renders frame before Blender updates mesh - so alembic mesh does not update during render.to Alembic caches are not updated during render if the `Frame Offset` Frame is driven (works when it is keyframed)This issue was referenced by
fd0bc7e002
Alembic caches are not updated during render if the `Frame Offset` Frame is driven (works when it is keyframed)to Alembic caches are not properly updated by driversChanged status from 'Confirmed' to: 'Resolved'
