Outliner "delete hierarchy" crash with a mesh in edit-mode #72667
Reference: blender/blender#72667
Operating system: Linux-4.18.0-25-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.116
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
f1aa4d18d4
Blender occasionally and unpredictably crashes when using "delete hierarchy" in the outliner and a 3d viewport is open
I have tried to generate a repeatable .blend example and I can not. I have a set of collections in a project and when I select one or several of the collections in the outliner, right click, and choose "delete hierarchy", there is an occasional crash.
Seeing the "view3d_main_region_draw" in the stack trace, if I change the 3d viewport to e.g. an image editor, this issue does not happen.
There are a lot of "howevers" here, though: once a test file stops crashing (as sometimes happened when I was trying to narrow things down into a demo project), it won't crash anymore, implying some kind of file state is contributing. Also, my original crashing project was using the animation nodes plugin. Not sure if that might play a role in "corrupting" the blend file somehow. (The crash happens when using a blank config dir, i.e. no animation nodes plugin is active, but the project opens with an "AN Tree" graph editor page.)
Crash log:
Added subscriber: @clepsydrae
Added subscriber: @ideasman42
Please attach a blend file which crashes (even if it doesn't crash reliably).
I will try -- if I can not, is there a private address I can send a file to?
Nevermind, I managed to get a reliable crash with this .blend.
If I open it, right click on "notes_and_labels" in the outliner, and "Delete Hierarchy", it crashes.
If I repeat this, but change the 3d viewport to an image editor and do the deletion, it does not crash.
dh4.blend
If I remove basically any of the other objects or collections, save the project, and re-open it, there is no crash. I couldn't narrow it down farther than this.
Thanks for looking at it.
This is caused by remove collection not exiting edit-mode.
Note that the crash points to BMEditMesh.ob pointer becoming stale, even if thats corrected (I tested removing the pointer locally), there is a crash in the draw manager.
We need a reliable way of exiting edit-mode on all objects which are removed when deleting the collection.
Looking into this further, there are two bugs in this area.
BMEditMesh.ob
pointer.For this report, a quick workaround could be to either exit edit-mode before removing the collection (flushing edits to object mode).
However, it seems like this kind of problem is something that could easily occur in other situations (removing collections from Python for example).
Freeing edit-mode data when deleting the object could work too, however it's not correct since this should be possible to support removing an object without clearing the object-data's edit-mode (since it may be used by another object), e.g: P1200.
Since this is related to ID removal, tagging @mont29
Added subscriber: @mont29
occasional crash when "delete hierarchy" in outliner is used and a 3d viewport is opento Outliner "delete hierarchy" crash with a mesh in edit-modeThis issue was referenced by
07a959067d
