Eeevee SSS Artifacts with Subsurface Translucency on #72695
6 Participants
Reference: blender/blender#72695
Operating system: MacOS 10.15.2
Graphics card: AMD Radeon Pro 5500M 8 GB
But it's worth noting I've also seen this on Windows machines with Nvidia cards.
Broken:2.81a (release), also broken in 2.82 latest alpha (December 25)
2.80 seems to have a similar problem, but it looks a little different and maybe not as extreme (though I haven't tested in all lighting situations)
When working with high contrast lighting setups, materials with SSS and subsurface translucency turned on generate artifacts that look a little like banding. This can be reduced to some degree by raising the shadow cube size, but I've yet to see it disappear entirely. This is especially frustrating since these are the exact kinds of lighting conditions that can make SSS really shine.
You can get this by setting up a material with SSS, scaling down the SSS scale, turning on subsurface translucency, turning off or lowering the environment lighting, then lighting the object with the material from the size. It can be finicky to get it to occur sometimes depending on your model and settings, but I've encountered it in a number of ordinary situations
Probably the easiest way to reproduce it is to just load up the attached blender file and hit render or turn on the viewport
mnkysss.blend
Added subscriber: @davidmikucki
Here’s a render showing the problem.
Added subscriber: @DanielBystedt
I get the same results with the scene that Davidmikucki provided. The issue seems to be directly related to soft shadows in Eevees render settings and also sss translucency as mentioned above.
The lighting seems a bit like a corner case scenario though. The SSS is extremely low. Using realtime rendering solutions will always present certain artifacts that needs to be fixed/hidden in my experience.
Here are some tweaks that can help with your rendering
This is super helpful, thanks! I'm not sure I understand what "SSS multed by 100" means, though? Could you elaborate?
I totally understand that realtime SSS, especially translucent SSS, is always going to have issues. But I don't know if I'd call this a corner case. These are pretty much the most realistic settings I've found for emulating skin SSS and I get it pretty much any time I try to set up dramatic lighting.
Added subscribers: @fclem, @mano-wii
@fclem, is this a known limitation or a bug?
Not sure if I correctly understand the limitations described here: https://docs.blender.org/manual/en/latest/render/eevee/limitations.html#eevee-limitations-sss
Sorry about my shorthand. By multing sss I mean that I multiply the scale of the SSS by 100. The sss has a larger radius in the edit that I made
Ah. Thanks. Yeah, you're right, Scaling the SSS up has an effect. It also seems to be the case that I would expect the SSS slider to affect the opacity of the SSS—but it actually seems to be a scale multiplier. So to get the scale right, then turn down the effect, I have to duplicate my node setup, turn off SSS on the duplicate mat, and then combine them with a mixer. This is giving decent results.
Maybe this isn't a bug? I'm not entirely sure at this point. Please feel free to close if it's just my misunderstanding of how to use SSS.
It is an artifact of using the shadowmap to create translucency effect. I already tried to mitigate the issue so I'm not sure I can really do much more.
I don't like adding user side hacks but this might be an instance where it is really needed.
Added subscriber: @lichtwerk
Just for reference: I think it was {131ac2ec82}?
Added subscriber: @viadvena
Operating system: Linux-4.15.0-109-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.83.2, branch: master, commit date: 2020-07-09 05:50, hash:
239fbf7d93
Similar issue... Translusency completely unusable for me.
SSS_Bug.blend
