[Eevee] Materials with 'Alpha Blend' are ignored in mist pass
Confirmed, NormalPublic
Operating system: Windows v10.0.18363.535 (Build 1909)
Graphics Card: NVIDIA GeForce MX150
Broken: v2.81a
Adding an "image as plane" into the scene create an 'Alpha Blend' transparency material.
When rendering the scene in the Eevee engine with the mist pass turned on, Eevee outright ignores the "image as plane" in the mist pass.
This does not happen if you set another type of transparency for the material.
In this case, Eevee correctly masks out the dimensions of the regular plane mesh in the mist pass.
  • Render the attached .blend file below and select/view the Mist pass.
One can see that the "image as plane" has been ignored while the regular plane mesh (with the image material) has been rendered with a holdout.
Germano Cavalcante (mano-wii) renamed this task from [Eevee] Why are "images as planes" ignored in mist passes? to [Eevee] Materials with 'Alpha Blend' are ignored in mist pass.Dec 30 2019, 7:47 PM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.
Germano Cavalcante (mano-wii) updated the task description. (Show Details)
