Issue with shared meshes overwriting modifiers #72733
7 Participants
Reference: blender/blender#72733
Graphics card: GeForce GTX 980/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 425.31
Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-26 19:15, hash:
d35a319687
All meshes that have shared mesh data (I mean they use same geometry)
will pop into the scene in edit cage display, regardless of what object you actually edit. Ok so far.
But in addition, they ignore their current modifier setup and use your currently
active object's modifiers to replace their own for the editing time. Why?
This creates bad visualization and editing conflicts, especially when
using those meshes heavily modified (Mask) and dependent on each other.
The current behaviour is very annoying to deal with.
I cant find a way to turn this off, therefore I assume its intended. Please correct me if this isnt true.
Otherwise see my file for a small showcase.
LinkedMeshesOverwrite.blend
Example:
Issue:
The first Cube is displayed red now while editing because the second Cube is rendered on top of it.
Issue 2:
You cant see at the same time whats going on for the second Cube with its own modifiers which might be relevant to the editing process. (for example hidden or skinned parts that are connected to the model)
Added subscriber: @karja
#68097 was marked as duplicate of this issue
#65324 was marked as duplicate of this issue
#73352 was marked as duplicate of this issue
Issue with shared meshes overwriting modifiers and edit cage stateto Issue with shared meshes overwriting modifiersAdded subscriber: @JacquesLucke
2019-12-28 13-41-00.mp4
edit-shared-mesh-bug.blend
Added subscriber: @mont29
This will most certainly require quite a bit of work to get fixed, so considering it a known issue for now.
Added subscriber: @OliverVillar
Added subscribers: @TherockyDoo, @Jeroen-Bakker, @brecht, @DanielBystedt
Added subscriber: @Frizzil
THe first mentioned issue has been solved. The second part was already solved. Materials are part of the mesh and is shared between the objects.
I will mark this issue completed as I this has fixed based on the mentioned steps to reproduce.
If this is not the case, please open a new issue explaining in detail the steps needed to reproduce.
Added subscribers: @jeremyhgs, @fclem
This issue was referenced by
0f89bcdbeb
