UDIMs don't behave properly on imported geometry #72734
Reference: blender/blender#72734
Operating system: 10.12.6
Graphics card: nVidia 980
Version 2.82 (2.82 2019-12-27)
geometry is mapped only with the first UDIM texture instead of all of them in Cycle. In Eevee, only one tile is shaded, the other ones are pink.
I made a cube in Maya where I spread each face on a different UDIM. Imported it in Blender. It looks perfect in Blender in the UV editor. I added a texture file (6 files named texture.1001,png, texture.1002.png etc and on the image are the numbers 1.1, 1,2, 1,3 etc, representing which UDIM they are) and turned on the tile option. It only maps the first texture (UDIM 1001). In Eevee, the other faces are pink and in Cycles all faces have texture 1001 assigned to them. I tried to use texture.0004 but once tile is turned on, it does the same thing. Also, even if texture.0004.png was picked, it shows me texture.0001.png in the texture editor. So Blender recognize that the textures are UDIMs, it just doesn't map them properly. See attached image.
Added subscriber: @Funnybob
Added subscriber: @lichtwerk
Just to make sure we are all on the same page:
Here you go! :-)
Archive.zip
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @LukasStockner
OK, looks like you just have to create the tiles in the
Image Editor
>Sidebar
>UDIM Tiles
panel (+
button next to the list)?UDIMtest_created_tiles.blend
Issue notes though:
#72390 (Improve UDIM functionality) is related here...
@LukasStockner : what do you think?
You have to support tiles being in any order possible (but never go beyond 10 on a row, that's the standard). If you get a model, let say, from Turbosquid that has UDIMs, they may not be in the perfect order. Or if you delete part of your geometry and it creates gaps in the UDIMs, it needs to be supported. So generating the tiles dynamically according to the image name is the way to go. Otherwise it's pointless. Last model I worked on had aver 100 UDIMs. I don't see myself moving UVs around and renaming all textures. That would be insane. :-)
OK, quick read shows that we are more or less in line with what most everyone does?
So you can do a grid like this (as long as it is based on 10s)
random article:
https://www.fxguide.com/fxfeatured/udim-uv-mapping/
So naming of tile
is rather exotic it seems? (at least for the first pic in a 2nd row?) Does Maya do this by default?Exactly. Can even have holes in the middle. They don't need to all touch each other.
This is behaving as expected.
UDIM tiles are automatically detected and loaded when you open any of them. However, this may conflict with sequence loading since they both detect numbers in the filename. Therefore, Blender uses a few rules to determine if something is a UDIM texture or a sequence. These rules are:
There must not be a file with a number above 1999
The third point is relevant here, because the 2001 file is preventing Blender from loading the texture as UDIM. According to the UDIM "spec", that file would correspond to the 101st row and 1st column, which I guess is not what you want. If you remove that file or rename it to 1011 (which it should be based on the UVs as far as I can see), it will work.
Maybe this can help. Different software use different ways of dealing with UDIM names. Maybe it would be important to support all 3 systems as you never know where stuff may come from. This is from Maya.
0-based (Zbrush) - select this option if your UV co-ordinates start at 0
Some applications, for example, Zbrush, number the UV tiles with the lower left UV co-ordinate. That is, a UV tile [0,0]x(1,1) would use u0_v0 in its file name.
1-based (Mudbox) - select this option if your UV co-ordinates start at 1
Some applications, for example Mudbox, number the UV tiles with the upper right UV co-ordinate. That is, a UV tile [0,0]x(1,1) would use u1_v1 in its file name.
2-UDIM (Mari) - select this option if your UV co-ordinates are represented as a four-digit number using the formula 1000+(u+1+v*10)
3-Explicit Tiles - select this option to load each tile separately and enter the U and V values explicitly. For each tile, enter the values of the lower-left UV co-ordinate that the texture corresponds to.
I believe Substance Painter used the Mari naming convention.
@LukasStockner : What I meant is that if you have a default tiled image with only one tile (1001) and then browse for a file like
are present], create the remaining 4 tiles automatically?Anyways, I think we can all accept that this report does not really confront us with a real bug, right?
All of the above are improvements to the existing (working) functionality, so while we could discuss this further here, there are better channels for this:
https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
If you opened the 1001 file for the first time, it will scan for additional tiles. If you already opened 1001 before, it won't re-scan.
Actually, having a "re-scan" operator is a good idea, I'll add it to the list.
Generally, yeah, this report can be closed.
@Funnybob Interesting, I wasn't aware that the other formats are in use. It is possible to add support for that, I'll add it to the list as well.
Actually, the way it works is the following. You open or import a file with UV spread on different UDIMs. Textures are irrelevant at this point as the UVs are part of the geometry. When you assign a textures (I use Maya as an example), when you select one of first tree options as mentioned in my previous message, the texture name will change from foo.0001.jpg (or foo.u1v1.jpg) to foo..jpg. Then Maya will seek textures according to the UVs. If it finds a texture in UDIM 4,5 (or 4005), it will assign the corresponding texture to the geometry. UDIMs are not created according to textures, unless you manually create them.
You (the user) don't want to rescan for textures. When you call the rendering engine, the engine will find the textures as it knows it's looking for UDIM textures (by choosing the tile option).
@Funnybob : at this point it seems a bit more manual in blender, but that could be considered as well?
It might find the tiles on disk, but it does not add them / create them for the list in the UDIM tiles panel:
In this case, you would not turn on the tile option. This is just regular UV mapping.
I actually don't understand why you need to make a tile list. I don't know of any 3D package the requires the user to create UDIMs. If you move the geometry outside 1,1, then it's on another UDIM and that's it. You just need to make sure that there's no overlap from one tile to another (a checking tool for that is a must). You can see on this image some geo where the UVs are on different UDIMs. But I didn't create them. I just moved the UVs where I wanted them.
Added subscriber: @Jeroen-Bakker
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
Lukas mentioned he adds it to his list for improvements, will close this report for now. As the last few comments are user/support related.
