Cycles GPU Compute fails on AMD Vega 64 ROCm with kernel compilation errors #72738
Reference: blender/blender#72738
Operating system: Linux-5.2.0-0.bpo.2-amd64-x86_64-with-debian-10.2 64 Bits
Graphics card: Radeon RX Vega (VEGA10, DRM 3.32.0, 5.2.0-0.bpo.2-amd64, LLVM 7.0.1) X.Org 4.5 (Core Profile) Mesa 18.3.6
Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-26 19:15, hash:
d35a319687
Rendering in Cycles with OpenCL fails with shader compilation errors.
Complete log:
Added subscriber: @richard.s
Added subscriber: @harish2704
I am also affected by the same bug.
OpenCL rendering failing on Vega56 GPU.
Important information from "System info"
Blender 2.81 (sub 16) System Information
Blender:
version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
f1aa4d18d4
, type: Releasebuild date: 2019-12-04, 13:48:07
platform: Linux
build cflags: -Wall -Wcast-align -Werror=implicit-function-declaration -Werror=return-type -Werror=vla -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Wformat-signedness -Wnonnull -Wuninitialized -Wredundant-decls -Wshadow -Wno-error=unused-but-set-variable -fuse-ld=gold -std=gnu11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -msse2 -D_GLIBCXX_USE_CXX11_ABI=0
build cxxflags: -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wuninitialized -Wundef -Wmissing-declarations -fuse-ld=gold -std=c++11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -msse2 -D_GLIBCXX_USE_CXX11_ABI=0
build linkflags: -Wl,--version-script='/home/sources/buildbot-x86_64-slave/linux_glibc217_x86_64_cmake/blender.git/source/creator/blender.map'
build system: CMake
Platform #1
Platform Name: AMD Accelerated Parallel Processing
Platform Vendor: Advanced Micro Devices, Inc.
Platform Version: OpenCL 2.1 AMD-APP (3052.0)
Platform Profile: FULL_PROFILE
Platform Extensions: cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
Number of devices: 1
Device: #0
Device Name: gfx900
Device Board Name: Vega 10 XL/XT [Radeon RX Vega 56/64]
Device Vendor: Advanced Micro Devices, Inc.
Device OpenCL C Version: OpenCL C 2.0
Device Profile: FULL_PROFILE
Device Version: OpenCL 2.0
Device Extensions: cl_khr_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_media_ops cl_amd_media_ops2 cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_depth_images cl_amd_copy_buffer_p2p cl_amd_assembly_program
Device Max clock frequency (MHz): 1590
Device Max compute units: 56
Device Max work group size: 256
Added subscriber: @RL
You should attach a log file instead of dumping the whole output here.
Added subscriber: @Jeroen-Bakker
You are using ROCm on top of Mesa. When using Cycles please use ROCm AMD ProDrivers. Looking at the compile errors it seems limitation of the Mesa OpenCL compiler, not a bender issue.
Hi @Jeroen-Bakker, thanks for looking into it! Just for reference, I followed the installation instructions from here https://rocm.github.io/install.html#performing-an-opencl-only-installation-of-rocm to perform an OpenCL-only installation of ROCm. I compiled and ran some OpenCL test programs and they worked without issues, so I falsely assumed it should also work with blender. I'll do as per your recommendation and set it up with the full ROCm AMD Pro drivers.
