Slow Download Performance on user manual #72753
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#72753
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
On your website, I have tried to DL the Manual 3 times already,
https://docs.blender.org/manual/en/latest/blender_manual.zip
and it keeps failing. Can you please change your DL settings to support resuming, and maybe lengthen the time to allow DL. This is getting frustrating that you don't have it set up right. GetRight doesn't even work.
Added subscriber: @Rick_Loll
Infrastructure: Blender.Orgto Slow Download Performance on user manualAdded subscriber: @Blendify
I can confirm performance is subpar, I am getting only 500kb/s. I am looking into potential causes.
Added subscriber: @dmcgrath
Hi,
Strange, I was able to resume file downloads just fine on my system. I can't speak for this app/addon/extension that you are using, however. Perhaps something is blocking range requests on your machine?
As for the speeds, we do have some limits in place. Some of by us due to our limited bandwidth, and some are by the ISP and out of our control. Generally we hit a limit of about 500 megabits/second on the outgoing traffic, but we also tend to find that traffic speeds to places outside of the EU are extremely shaped down to very slow speeds. For example, I can pull a solid gigabit from the rack to a machine in Amsterdam, or from a Google VM in .EU, but at the same time I may only be able to pull about 15mbit/sec to anything in America.
While I can't be sure what the ISP does, it has been a general consensus over the years that they either are shaping our traffic out of the country, likely due to costs, or are placing our "free sponsored bandwidth" down to a very low priority that impacts the transfer speeds when going across continents.
I did double check the bandwidth during my tests, and the server where the download comes from indeed wasn't at maximum configured capacity, so something between you and our server is likely the limit, most likely our XS4ALL ISP. Otherwise, not a whole lot that I can do as I am not in control of upstream restrictions. Sorry!
Edit: I was also able to pull 12MB/sec from the Studio in Amsterdam from the datacenter, so that seems fine, given that it's only a 200Mbit link.
I'm going to close the report then. Thanks for looking into the issue Dan.
