'Dissolve' operator leaves inconsistent selection #72806
Reference: blender/blender#72806
Broken: 2.82 (
62d131e962
) (down to, and including, 2.79)Worked: N/A
After dissolution of edges in Edge selection mode, some vertices not connected with edges remain selected (which is indicated by a tool gizmo, Verts readout in the status bar, and verified by switching to Vertex selection mode).
It would seem that the vertices do remain "selected" for operators as well: after (4) or (8) you can transform those verts using a gizmo or shortcuts, extrude them (with strange results), connect them using Fill or Connect Vertex Path, and delete them (even though you're in Edge mode).
Update: Video demo here .
Added subscriber: @Stan_Pancakes
Added subscriber: @mano-wii
By
"box-select one square at the corner of the Grid"
you mean this?:In this case the vertices of the selected edges will also be deleted, so they will not appear as selected.
That doesn't seem like a bug to me.
One square, as in one face :) But it shows with your example too. After doing a ctrl+x, look at the stats. You should have one edge and one vert selected (should be impossible when an edge is selected), and switching to vertex mode will only have one corner vert selected.
EDIT: furthermore, switching back to edge mode will then still select an edge (from one vertex), and this time with 2 verts. :-=\
Added subscriber: @ideasman42
I can confirm. The resulting edge is selected but one of its vertices is not.
Theoretically in code this is possible, but for the user this can get in the way of operations like transform for example.
This patch would solve most cases with this incosistence.
But the real solution might be to flush the mesh after calling the operator.
I don't know if this qualifies as a bug or known issue.
@ideasman42, what do you think?
It's not just transform, simple mode switching can also bring unexpected results (see the video linked in the description).
Added subscriber: @mont29
Would consider this as a bug for now, afaik tools should always leave selection in a state that is consistent with current selection mode?
