It is not possible to switch from "English Input to Korean Input" in TEXT mode.
Confirmed, NormalPublicKNOWN ISSUE
Operating system:win10_64
Graphics card:inner
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Hello. I am Korean. Thank you for developing the blender. I'm using the latest version of blender. But there's one serious problem.
This is also true of Chinese and Japanese keyboards.
We would appreciate it if you could correct the "Switching language input" bug in TEXT mode.
Hello,
In order to use Blender in the Korean language you must go to Edit / Preferences / Interface and turn on "Translation" and select your language. Doing so changes the font used for the program to one that contains characters for very many languages.
Unfortunately doing so does not automatically change the font used when inserting "Text" objects. Therefore, while your new text object is selected you must go to Properties / Object Data / Font and select a font that contains characters needed for your language. The default font (Bfont) does not contain any Korean characters. You can select the international font that comes with Blender (droidsans.ttf.gz) or any others on your computer. Sorry for the inconvenience. We are hoping to improve this in the future.
ronsn (ronsn) changed the task status from Needs Triage to Needs Information from User.Wed, Jan 1, 4:43 AM
Dalai Felinto (dfelinto) changed the task status from Needs Information from User to Confirmed.Mon, Jan 13, 6:10 PM
Dalai Felinto (dfelinto) changed the subtype of this task from "Report" to "Known Issue".
@ ronsn (ronsn) thanks for helping with triaging but this report is not waiting for information from the user.
Filing this under known issue
