Graphics card: GeForce GTX 1070 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-30 18:20, hash: rB56ef761381ec
Using box select is extremely unreliable while in Face select or Edge select mode (I didn't observe any problems in Vertex mode). It may end up selecting non-visible faces/edges inadvertently and with seemingly no pattern to its misbehavior or workarounds (shrinking range of the clip start/end doesn't fix it, enabling face centers doesn't fix it etc.)
This problem has existed for some time now but today I finally got fed up with it after losing several minutes of work again.
I'm using a hidpi 4k screen, using Blender's UI scaling of 1.0, and OS scaling of 2.0 in case this matters.
- Start with default .blend
- Enter edit mode and Subdivide cube twice
- Switch to Face select mode (or Edge select mode)
- Attempt to box-select a variety of faces on the cube
- Notice that more often than not, extra faces which are not visible are still selected
No selection
Selecting all visible faces with box-select
Non-visible faces being selected :(
Non-visible edges being selected :(
