Subdivision Modifier unusal RAM usage #72884
6 Participants
Reference: blender/blender#72884
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.28
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
f1aa4d18d4
Opening the attached examplefile (~60MB) with visible subdivision modifiers the used system RAM is very high (~33GB).
After rendering the used system RAM is "cleared" and the example file only uses about 800MB.
Cookies Subd visible.blend
Cookies Subd hidden.blend
Opening the attached examplefile "Cookies Subd visible.blend" (~60MB) with visible subdivision modifiers the used system RAM is very high (~33GB).
File size: 61.804KB
RAM Usage after opening: ~33GB
RAM Usage initializing Render GPU(1x2080ti): ~60GB
RAM Usage while rendering: ~5GB
RAM Usage after render: ~800MB
With hidden subdivion modifier there is a expectable RAM usage (File: "Cookies Subd hidden.blend"):
File size: 61.804KB
RAM Usage after opening: ~360MB
RAM Usage initializing Render GPU(1x2080ti): ~35GB
RAM Usage after render: ~400MB
Added subscriber: @Tschonatschan
Added subscribers: @Sergey, @mano-wii
I can't open the file on my system with 16GB of RAM.
I believe the file has very heavy settings to handle the Subdivision modifier.
If so, this is not considered a bug. The user has to be aware of the limitations when setting up a modifier.
@Sergey, if I'm not mistaken, you've worked with this modifier a few times, any idea why the memory decreases after rendering?
I can confirm that the memory usage by that file is high.
However, the file itself is unsuitable for any debugging in my system with 32 GB RAM.
@Tschonatschan, please try to simplify the file so much that the peak RAM usage is below, let's say 10gb.
Sorry for the late response. After testing a bit I got some weird results.
The original scene consisted of 5 similar objects. To decrease peak RAM usage i deleted one after another, saved in a separate file, closed and opened fresh before hitting render. Here are the results:
5 Objects
File size 62MB
RAM usage:
open 33GB
init 61GB
render 5GB<-------- This is the really weird stat
after 800MB <-------- This is the really weird stat
4 Objects
File size 50MB
RAM usage:
open 26GB
init 56GB
render 30GB
after 26GB
3 Objects
File size 37MB
RAM usage:
open 20GB
init 41GB
render 20GB
after 20GB
2 Objects
File size 25MB
RAM usage:
open 13GB
init 29GB
render 15GB
after 13GB
1 Object
File size 13MB
RAM usage:
open 6,8GB
init 15GB
render 8GB
after 6,8GB
I tried to delete the objects in a different order, but got the same results.
The mesh is heavily subdivided, In case of the original file with 5 objects blender is fully operable with 33GB or 175MB of RAM usage, without any performance differences.
First i thought it was because I got 64GB RAM installed and it uses ssd for memory. But similar results on a 96GB RAM PC.
Any hints on how i can investigate furthermore?
Added subscriber: @ideasman42
Please provide a simplified blend file which doesn't use too much memory (10gig peak), then give exact steps to redo the problem, what happens, what you expect.
Added subscriber: @Blendify
Changed status from 'Needs User Info' to: 'Resolved'
Added subscriber: @Goury
Please reopen.
Blender still uses ridiculous amounts of ram for multires subdivisions for no good reason.
Bug or not, this have to be optimised.
Using a couple of terabytes(!) of ram to achieve good smooth detail is pure madness.
Yet it is how it is when it comes to a reasonably large and detailed object.
It's especially maddening when the ram required to do everything else after initial loading is around just 5-7 GB.
D12406 will improve memory use for the common case, I don't think it helps to keep this open unless there is a spesific case that can be identified.
Showing a complex file with high memory use isn't something we typically handle in bug reports.
okay
