2.82 Documentation
Closed, ResolvedPublicTO DO
List of Blender 2.82 features still need their entry in the manual:
  • rBd5ca72191c3 Cycles: Add OptiX AI denoiser support (Patrick Mours)
  • rBfdf89acc863 Sculpt: Pose Brush with Inverse Kinematics (Pablo Dobarro)
  • rB03145616843 Sculpt Add color alpha controls to the brush cursor (Pablo Dobarro)
  • rB0406eb11033 Maths Node Additional functions (Charlie Jolly)
  • rB11d92718044 Image Editor Add option to fill UDIM tiles during creation (Lukas Stockner)
  • rB15f82278d5d Sculpt_Paint Dash Ratio and Dash Samples (Pablo Dobarro)
  • rB186bd1759f0 Pose brush Smooth Iterations Brush Property (Pablo Dobarro)
  • rB316107d4cd1 Sculpt New Clay Brush (Pablo Dobarro)
  • rB39112a4f7b2 UI Remove orphan datablocks directly from File-)Clean Up menu (Antonio Vazquez)
  • rB3ea736fb4d6 Keymap use the application key for the context menu (Campbell Barton)
  • rB44d67b6dc8b Transform Add option to exclude back facing geometry from snapping (mano-wii)
  • rB470fe59f7e8 Sculpt Mask Slice (Pablo Dobarro)
  • rB47645a8db62 Sculpt Sample Voxel Size (Pablo Dobarro)
  • rB541d0fdba61 Add cloth pressure vertex group and unlock cloth shrink values range (Sebastian Parborg)
  • rB56ef761381e Image Editor Initialize Add Tile options from current tile (Lukas Stockner)
  • rB62ef59aa0cc Add the ability to create internal springs to the cloth sim (Sebastian Parborg)
  • rB6c9be3b27ce Sculpt Enable symmetrize operator with Dyntopo disabled (Pablo Dobarro)
  • rB71ddcf1a088 Paint Smoother curve preset (Pablo Dobarro)
  • rB7868db9343d Make curve decimation only take into account the selected curve points (Sebastian Parborg)
  • rB7dd6e034f1c Animation Added option to playblast only keyframes of selected objects (Sybren A. Stüvel)
  • rB8bc57e5b91e Add curve decimate in the graph editor (Sebastian Parborg)
  • rB9064655a70c Mantaflow [Part 10] Updated fluid modifier settings (Sebastián Barschkis)
  • rB91248876e51 GPencil MultiStroke modifier (YimingWu)
  • rB9251b077203 Sculpt_Paint Remove Unified SIZE_PRESSURE and ALPHA_PRESSURE (Pablo Dobarro)
  • rB958d0d4236b Shader Nodes Add Interpolation modes to Map Range node (Charlie Jolly)
  • rB96a1bc2997c GPencil Invert Simplify options (Antonio Vazquez)
  • rB98ff6cfa575 GPencil Add Opacity y Onion switch to Dopesheet (Antonio Vazquez)
  • rBa01ba66cf69 Clip Editor Allow opening and creating images from Plane Track panel (Sergey Sharybin)
  • rBa47f694b865 Sculpt Topology Slide_Relax (Pablo Dobarro)
  • rBa482d940bc1 Sculpt Invert Scrape to Fill (Pablo Dobarro)
  • rBa7fcd78d2d6 User Preference Experimental Tab (Dalai Felinto)
  • rBaadc90d0fc6 Stretch To implement a mode similar to Damped Track for rotation. (Alexander Gavrilov)
  • rBb037ba2665f UI Changes to Graph Editor selection and transform (Julian Eisel)
  • rBb0e7a1d4b49 Alembic improved import_export of mesh normals (Sybren A. Stüvel)
  • rBb214e06b02e Clip Editor Remove Image label from selector (Sergey Sharybin)
  • rBb423b891274 Tool System enable fallback tool by default (Campbell Barton)
  • rBb6973ed760b Keymap pressing leader key (Alt) again closes tool prompt (Campbell Barton)
  • rBba1e9ae4733 Bevel Custom Profile and CurveProfile Widget (Hans Goudey)
  • rBc30d6571bb4 Add support for tiled images and the UDIM naming scheme (Lukas Stockner)
  • rBc3279be222b Sculpt Multiplane Scrape Brush (Pablo Dobarro)
  • rBd4bef6a2150 VSE add a Set frame range to Strips operator (Alessio Monti di Sopra)
  • rBd66bc3807f9 GPencil Layers and Materials Specials menu updates (Matias Mendiola)
  • rBd7a8a606889 UI Add extra bevel options to popover from tool settings bar (Hans Goudey)'
  • rBd9e61ce1953 Alembic changed 'Visible Layers' to 'Visible Objects' in export options (Sybren A. Stüvel)
  • rBdfe965bee24 UI tweaks to the brush Stroke panel (William Reynish)
  • rBe0cd5b980fc Image Editor Add option to create multiple tiles at once (Lukas Stockner)
  • rBe45cfb574ee Solidify Modifier support non-manifold input (Henrik Dick)
  • rBe760972221e Cycles support for custom shader AOVs (Lukas Stockner)
  • rBe98d27fd8d4 Keymap use tab key for indent or auto-complete (Campbell Barton)
  • rBf6cefbef22c Fix T30941 Add cloth air pressure simulation (Sebastian Parborg)
  • rBf9e65fcea72 Textures Support UDIM images (Lukas Stockner)
  • rBfb74dcc5d69 UI Brush Settings overhaul (William Reynish)
Related Objects
Mentioned In
T51172: Documentation Module
T73257: Release notes for 2.82
Mentioned Here
T74013: Update Remaining Fluid Documentation
rBfdf89acc8634: Sculpt: Pose Brush with Inverse Kinematics
rBd5ca72191c36: Cycles: Add OptiX AI denoiser support
T30941: Blender cloth simulator air pressure enhancement
rB44d67b6dc8b9: Transform: Add option to exclude back facing geometry from snapping
rBd4bef6a21508: VSE: add a Set frame range to Strips operator
rBe45cfb574ee7: Solidify Modifier: support non-manifold input
rBb0e7a1d4b492: Alembic: improved import/export of mesh normals
rBaadc90d0fc67: Stretch To: implement a mode similar to Damped Track for rotation.
rBa7fcd78d2d69: User Preference Experimental Tab
rBbcf008516f6e: UI: Graph Editor Insert Keyframes Menu
rB91248876e517: GPencil MultiStroke modifier
rBb6973ed760b7: Keymap: pressing leader key (Alt) again closes tool prompt
rBd66bc3807f92: GPencil: Layers and Materials Specials menu updates
rBba1e9ae4733a: Bevel: Custom Profile and CurveProfile Widget
rB8bc57e5b91eb: Add curve decimate in the graph editor
rB15f82278d5d4: Sculpt/Paint: Dash Ratio and Dash Samples
rBc7ade50deee7: Clay Strips: Input pressure curve and new defaults
rB316107d4cd11: Sculpt: New Clay Brush
rB6c9be3b27ce8: Sculpt: Enable symmetrize operator with Dyntopo disabled
rBc3279be222bd: Sculpt: Multiplane Scrape Brush
rB470fe59f7e87: Sculpt: Mask Slice
rB186bd1759f05: Pose brush: Smooth Iterations Brush Property
rBa47f694b8652: Sculpt: Topology Slide/Relax
rBa482d940bc16: Sculpt: Invert Scrape to Fill
rBe98d27fd8d43: Keymap: use tab key for indent or auto-complete
rBb037ba2665f4: UI: Changes to Graph Editor selection and transform
rB71ddcf1a0883: Paint: Smoother curve preset
rBa01ba66cf697: Clip Editor: Allow opening and creating images from Plane Track panel
rBb214e06b02e8: Clip Editor: Remove Image label from selector
rB98dfb4dd1c8c: Allow deletion of directories in the file browser
rBf6cefbef22c8: Fix T30941: Add cloth air pressure simulation
rB9251b077203c: Sculpt/Paint: Remove Unified SIZE_PRESSURE and ALPHA_PRESSURE
rB47645a8db622: Sculpt: Sample Voxel Size
rB9e3006e5079c: Clay Brush: Input curves and update defaults
rB53f27cdc2053: UI: use popover for NDOF menu
rB9e168b63b4a4: GPencil: Add missing Overlay mode
rBd9e61ce1953b: Alembic: changed "Visible Layers" to "Visible Objects" in export options
rBfcdf4b36c53c: UI: group NDOF XYZ invert options
rB541d0fdba61a: Add cloth pressure vertex group and unlock cloth shrink values range
rB98ff6cfa575b: GPencil: Add Opacity y Onion switch to Dopesheet
rB7868db9343d5: Make curve decimation only take into account the selected curve points
rB0406eb110332: Maths Node: Additional functions
rB958d0d4236b1: Shader Nodes: Add Interpolation modes to Map Range node
rB9c1134015c34: UI: Custom Face Orientation Colors
rB3d5775b69ada: Gizmo: add view aligned gizmo for shear
rB62ef59aa0cca: Add the ability to create internal springs to the cloth sim
rB3ea736fb4d65: Keymap: use the application key for the context menu
rB96a1bc2997c8: GPencil: Invert Simplify options
rBe760972221e6: Cycles: support for custom shader AOVs
rBd7a8a606889f: UI: Add extra bevel options to popover from tool settings bar
rBc30d6571bb47: Add support for tiled images and the UDIM naming scheme
rB82755f513706: Gizmo: add gizmos for UV transform translate/rotate/scale
rBfb74dcc5d69d: UI: Brush Settings overhaul
rBdfe965bee24d: UI: tweaks to the brush Stroke panel
rB9064655a70c6: Mantaflow [Part 10]: Updated fluid modifier settings
rB11d927180444: Image Editor: Add option to fill UDIM tiles during creation
rBe0cd5b980fc5: Image Editor: Add option to create multiple tiles at once
rB7dd6e034f1ca: Animation: Added option to playblast only keyframes of selected objects
rB39112a4f7b2b: UI: Remove orphan datablocks directly from File->Clean Up menu
rBf9e65fcea72f: Textures: Support UDIM images
rB03145616843e: Sculpt: Add color alpha controls to the brush cursor
rB56ef761381ec: Image Editor: Initialize Add Tile options from current tile
rBb423b891274a: Tool System: enable fallback tool by default
Aaron Carlisle (Blendify) changed the task status from Needs Triage to Confirmed.Jan 3 2020, 6:56 PM
Aaron Carlisle (Blendify) created this task.
Aaron Carlisle (Blendify) closed this task as Resolved.Feb 19 2020, 6:32 PM
Aaron Carlisle (Blendify) claimed this task.
Remaining fluid docs will be handled as part of T74013
