VSE Color Strip gives incorrect results when using RGB values greater than 1.0 #72890
Reference: blender/blender#72890
Version: 2.82 alpha (Jan. 3rd, a854...) Linux 64
Color Strip Bug.blend
How to reproduce:
Render and look upon the result
Although the desired color, in scene referred space, should be [16.0, 16.0, 16.0], the result is actually darker than if the color were set to [1.0, 1.0, 1.0]! The color management settings for the scene do not fix this issue, nor do any of the strip's parameters, including the "Convert to Float" option.
This is a serious flaw in the video sequencer, especially since Filmic is Blender's default color transform and the user will often need color values greater than 1.0.
Added subscriber: @rocketman
Added subscriber: @ronsn
For the VSE you should not use Filmic. Use Raw, or Standard in the Color Management instead. Btw. rgb(1.0, 1.0, 1.0) means rgb(100%,100%,100%) or if you use hexadecimal it's #FFFFFF .
Added subscriber: @Blendify
This is because the video sequencer is un aware of a scene reference workflow. It was designed on simple terms when HDR was not a concept. It is quite a large task to properly fix this and it is a known problem. Due to the fact that this is just a known problem I am closing the report. Everything works as it was orginally designed for however today's modern workflow require some huge modifications.
