Object Manipulator (Gizmo) does not draw until to disable and then re-enable
Confirmed, NormalPublicBUG
Operating system: Darwin-17.2.0-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GTX 1050 Ti OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-10.27.6 378.10.10.10.20.109
Broken: version: 2.82 (sub 6), branch: master, commit date: 2020-01-03 05:28, hash: rBeb6ca6cf9f28
When you switch from one of the transform tools (Move/Rotate/Scale/Transform) back to another tool, say the lasso select.
This enables the Gizmo manipulators, but if you didn't have any objects selected when you switched to the move tool, it won't draw the manipulators when you switch back.
Unless you disable and then re-enable them
see video.
-enable Object gizmos (any)
-then deselect all objects (or have no objects selected at step 1)
-switch to the move tool, for example
-select an object
-switch to the lasso select
the manipulators will not display until you disable and re-enable them.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Tue, Jan 7, 9:48 PM
Those are very specific steps, but in fact it seems to be a bug.
