Crash after going out of multi object edit mode #72979
Closed
opened 2020-01-08 22:03:40 +01:00 by Anton Gluhov · 6 comments
system-info.txt
Pack of street props unwrap.blend
OS - Windows 10
GPU - ASUS GTX 960 4gb
CPU - I4690 k
Steps to recreate the bug
  1. Select all the unhidden objects
  2. Go into edit mode
  3. Go into object mode
  4. Try to select any object (I select with the right mouse button)
The bug can be avoided by unhiding the rest of the objects after step 3.
If the bug doesn't occur, after going into edit mode try to play with uv islands (rotate, rescale, e.t.c.)
  • another crash can happen during the editing of the uvs, it happens randomly, but very often during basic editing functions like rotating, moving, rescaling. Happens more often if multiple objects were selected. To recreate this one try to go in and out of edit mode, selecting different objects, play with uvs, and eventually, you should stumble upon it.
[system-info.txt](https://archive.blender.org/developer/F8266506/system-info.txt) [Pack of street props unwrap.blend](https://archive.blender.org/developer/F8266516/Pack_of_street_props_unwrap.blend) OS - Windows 10 GPU - ASUS GTX 960 4gb CPU - I4690 k Steps to recreate the bug 1. Select all the unhidden objects 2. Go into edit mode 3. Go into object mode 4. Try to select any object (I select with the right mouse button) The bug can be avoided by unhiding the rest of the objects after step 3. If the bug doesn't occur, after going into edit mode try to play with uv islands (rotate, rescale, e.t.c.) + another crash can happen during the editing of the uvs, it happens randomly, but very often during basic editing functions like rotating, moving, rescaling. Happens more often if multiple objects were selected. To recreate this one try to go in and out of edit mode, selecting different objects, play with uvs, and eventually, you should stumble upon it.
Author
Added subscriber: @VermossomreV
Member
Added subscriber: @lichtwerk
Member
Member
Confirmed checking...
Member
There is a multi-user mesh being edited edited in multi-object mode.
Decor_detail_2 _high / Decor_detail_2 _low both share the Plane mesh.
One of the corresponding objects is in a collection visible to the viewports, the other one is in a collection that is not visible to viewports.
As a workaround, make sure you dont have a multi-user mesh in a non-visible collection, but yes, clearly a bug.
This has also been reported before, see #69834 ( Crash: Multi-object edit containing a (multiuser) mesh that is also used by an object in a hidden collection destroys CustomData layer), wiil merge these reports...
There is a multi-user mesh being edited edited in multi-object mode. `Decor_detail_2 _high` / `Decor_detail_2 _low` both share the `Plane` mesh. One of the corresponding objects is in a collection visible to the viewports, the other one is in a collection that is not visible to viewports. As a workaround, make sure you dont have a multi-user mesh in a non-visible collection, but yes, clearly a bug. This has also been reported before, see #69834 ( Crash: Multi-object edit containing a (multiuser) mesh that is also used by an object in a hidden collection destroys CustomData layer), wiil merge these reports...
Member
Closed as duplicate of #69834
2 Participants
Reference: blender/blender#72979
