Infinite viewport render loop when using Stereoscopy from camera view
Closed, DuplicatePublicBUG
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.15
Broken: version: 2.82 (sub 6), branch: master, commit date: 2020-01-09 19:46, hash: rB9d95c035c599, and 2.81 as well
The render always loops on sample 1 when viewing the rendered scene from the camera viewport, while steroscopy is turned on
Switch render engine to Cycles
Turn Stereoscopy on on the Output settings
Turn on Rendered viewport
Put yourself in Camera view
Yep, I can confirm that. Only way around that is to switch to either Left or Right Eye in View settings of 3D Viewport. Disabling left or right eye in Stereoscopy settings of render panel doesnt help.
Sebastian Koenig (sebastian_k) changed the task status from Needs Triage to Confirmed.Fri, Jan 10, 1:36 PM
This did work in 2.79. It did not try to render both eyes simultaneously as it seems to be the case now, but was always rendering one eye, no matter what you set in the stereoscopy panels.
Jeroen Bakker (jbakker) changed the subtype of this task from "Report" to "Bug".Fri, Jan 10, 4:38 PM
We should do a bisect on this issue to find out the commit that introduced this behavior.
