"Assign Material Slot"-Shortcut is created in the wrong place
Confirmed, NormalPublicKNOWN ISSUE
Graphics card: GeForce GTX 980/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 425.31
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash: rB26bd5ebd42e3
"Assign Material Slot"-Shortcut is created in the wrong place, therefore does not work.
By rightclicking, the shortcut is created in the Input Preferences under 3D-View > Object Mode > Object Mode (Global) which is wrong. It simply does nothing in Object mode. In order to work it has to be manually created under 3D-View > Mesh > Mesh (Global) with the same entry name.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Fri, Jan 10, 3:15 PM
Might turn out as a known limitation, but will confirm for now...
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".Tue, Jan 14, 3:07 PM
It is a known issue, has been since the early days of 2.5x project I guess… Some operators are just fairly hard to manage that way. Note that work as expected when materials are assigned to object and not obdata…
Don’t think @Jacques Lucke (JacquesLucke) should have closed T71896 tbh, this one and T73022 are essentially same problem. Will keep both open for now though.
