Official built of Blender crashes with opencl-intel package installed - not if I compile Blender myself or using fedora package
Needs Developer to Reproduce, NormalPublicKNOWN ISSUE
Operating system: Fedora 31
Graphics card: Intel Corporation UHD Graphics 620 (Whiskey Lake)
Broken: (example: 2.81a
  • Blender official crashes when Rendering with LuxCoreRender on OpenCL devices
  • No problem with Fedora RPM from repository
I tried with 2 versions:
  • the built 2.81a from blender website
  • the RPM from Fedora package (not the flathub version, I use the RPM from repository).
I only:
  • open Blender
  • press F12 to render the default cube
  • Official built: crash
  • Fedora built: rendering OK
Both can list my OpenCL device in GPU list in LuxCoreRender tab.
The "problem" is that Fedora Package doesn't have ffmpeg options and so on.., and is often not quickly updated. I'd rather use the official build.
Yes, I know :) , Blender only officially supports NVidia CUDA/OpenCL and Radeon for Cycles, but here I'm using LuxCoreRender that is able to use any OpenCL device.
Here some informations:
$ clinfo --list
Platform #0: Intel(R) OpenCL HD Graphics
 `-- Device #0: Intel(R) Gen9 HD Graphics NEO
$ dnf info intel-opencl
Last metadata expiration check: 0:01:11 ago on Fri Jan 10 15:17:07 2020.
Installed Packages
Version      : 19.52.15209
Release      : 1.fc31
Architecture : x86_64
Source       : intel-opencl-19.52.15209-1.fc31.src.rpm
Repository   : @System
From repo    : copr:copr.fedorainfracloud.org:jdanecki:intel-opencl
Summary      : Intel(R) Graphics Compute Runtime for OpenCL(TM)
URL          : https://github.com/intel/compute-runtime
License      : MIT
Description  : Intel(R) Graphics Compute Runtime for OpenCL(TM).
$ dnf info blender
Last metadata expiration check: 0:01:36 ago on Fri Jan 10 15:17:07 2020.
Installed Packages
Epoch        : 1
Version      : 2.81a
Release      : 3.fc31
Source       : blender-2.81a-3.fc31.src.rpm
From repo    : updates
Summary      : 3D modeling, animation, rendering and post-production
URL          : http://www.blender.org
License      : GPLv2
Description  : Blender is the essential software solution you need for 3D, from modeling,
             : animation, rendering and post-production to interactive creation and playback.
             : Professionals and novices can easily and inexpensively publish stand-alone,
             : secure, multi-platform content to the web, CD-ROMs, and other media.
The "official" built of Blender gives that crash log:
# Blender 2.81 (sub 16), Commit date: 2019-12-04 11:32, Hash f1aa4d18d49d
Connected to node manager  # Info
Saving copy of  blend file.  # Info
local ready  # Info
local is synced  # Info
Connected to render node server  # Info
bpy.context.space_data.context = 'RENDER'  # Property
bpy.context.scene.render.engine = 'LUXCORE'  # Property
bpy.context.scene.luxcore.config.device = 'OCL'  # Property
bpy.context.scene.luxcore.opencl.devices[0].enabled = True  # Property
bpy.context.scene.luxcore.opencl.use_native_cpu = False  # Property
# backtrace
./blender(BLI_system_backtrace+0x1d) [0x14ee84d]
./blender() [0x12cbb79]
/lib64/libpthread.so.0(+0x14b20) [0x7fe592c19b20]
/lib64/libpthread.so.0(raise+0x145) [0x7fe592c199a5]
Note: Cycles doesn't see my OpenCL device while LuxCoreRender is able to use it, that's a pitty.
I confirm that compiling myself with fedora openimage opencolor oidn and so on... is OK. The interface doesn't freeze when I go to settings, and LuxCoreRender works.
BTW: my GPU is still not seen in OpenCL tab, while LuxCoreRender see it and can use it. Any way to understand why Blender cannot see my OpenCL device ? (I will open a new issue for that)
Thanks for the report.
Have you tried to report this issue to the Lux Core bug tracker?
https://github.com/LuxCoreRender/BlendLuxCore/issues
Cycles does not support all versions of OpenCL, nor all GPUs. There is a reason for that.
backtrace shows that the crash occurs in the blender module. But you can't tell from it if it's a bug or a misuse of the API.
BlendLuxCore is not an addon officially maintained by blender, so unless we can reproduce the problem without that addon, there's not much we can do.
Hi,
What I'm reporting is that "your" built is not compatible with LuxCore addon with Intel, while the one I compiled myself on Fedora or the RPM from repository is OK. Actually there is another problem:
  • I removed LuxCore Addons
  • I start "your" blender build
  • I go on settings => Blender Freezes
I tried to compile with your built dependencies and Blender Crashes:
  • when I go to settings, with or without Luxcore enabled
  • when I launch LuxCore render (freeze)
One more time, if I compile with distribution packages (OpenImage, OIDN, ...) there is no problem (excepting Cycles ignoring my card, but yes I know that you do not support it for now)
What I'm pointing is that the official build from blender.org crashes with opencl-intel package. If I remove the driver, your build of Blender works as excpected. So, no, LuxCoreAddon is not the problem :)
Patrice (metal3d) renamed this task from Official built of Blender crashes at render with LuxCoreRender (not with RPM version) to Official built of Blender crashes with opencl-intel package intalled - not if I compile Blender myself or using fedora package.Mon, Jan 13, 4:28 PM
Patrice (metal3d) renamed this task from Official built of Blender crashes with opencl-intel package intalled - not if I compile Blender myself or using fedora package to Official built of Blender crashes with opencl-intel package installed - not if I compile Blender myself or using fedora package.
Germano Cavalcante (mano-wii) reopened this task as Needs Triage.Mon, Jan 13, 4:31 PM
You can see that comment: https://github.com/intel/compute-runtime/issues/194#issuecomment-517619116 it seems that the official build uses static LLVM
This comment also seems to resolve the "hang" that I have as well: https://github.com/intel/compute-runtime/issues/194#issuecomment-518299895
Just one more message to be sure that:
  • you don't think my message is aggressive :) I'm not English and I probably write without the good words
  • I don't ask to be able to use NEO opencl with Cycles, I know that you work hard to make Blender great, I can use crowd-render on external GPU for Cycles
I just realized that the problem is not Lux but the intel-opencl package that breaks the official build while compiling myself and/or using Fedora build is OK. I'm sure that the problem comes from linked libraries or something like that.
Here is my CMakeCache file that I use with Blender 2.82 branch if it can help
Regards,
Patrice (metal3d) added a comment.EditedMon, Jan 13, 4:55 PM
Note that the problem is very similar with issue T68052 - I needed to remove Clover too.
Hello,
The problem remains with 2.82 beta, downloaded from blender.org. Blender freezes at start time, no way to exit. IfI build my own, no problem.
I give an strace output as attachment.
Regards
Jeroen Bakker (jbakker) changed the task status from Needs Triage to Needs Developer to Reproduce.Tue, Jan 21, 8:41 AM
Jeroen Bakker (jbakker) changed the subtype of this task from "Report" to "Known Issue".
@Patrice (metal3d) could it be that you don't compile with LLVM and that works as there are no conflicts during symbol loading of common shared objects? see https://developer.blender.org/T68052
