Multiple IK chains influencing the same bone don't work #73051
7 Participants
Reference: blender/blender#73051
Graphics card: Intel(R) UHD Graphics 620 Intel 4.5.0 - Build 25.20.100.6472
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash:
26bd5ebd42
Worked: 2.79
I have a rig for a human. In blender 2.81 I set IK constraint (chain length 5) on the wrist and when I move it the finger bones follow. I set another on the thumb (chain length 4). Now when I move the wristIK the thumb bones stay where they are, they don’t follow. If I lower the chain length to 3 the thumb bones start to follow the wrist.
Open this file with blender version 2.81a:
#73051-multiple-IK-constraints.blend
Select wristIK and move it around. The bones that are the thumb (finger1-1.R, finger1-2.R, finger1-3.R) doesn't move.
Select finger1-3.R and set chain length to 3. Now when the wristIK is moved around the bones follow.
Open rig_support_blender2_79.blend rig_support_blender2_79.blend with blender version 2.79b. In this blend file the bones follow when wristIK is moved even when chain length is set to 4 for finger1-3.R.
I hope this is a bug and chain length should work the same between the versions. Because this is an animated character and I was hoping to be able to append it in newer blender versions and get the same result. With this behaviour the vertices gets wrong and if I lower the chain length I have to redo everyting.
Added subscriber: @BlenderAmateur
#67232 was marked as duplicate of this issue
#61621 was marked as duplicate of this issue
#63136 was marked as duplicate of this issue
#73262 was marked as duplicate of this issue
Added subscriber: @mano-wii
I can confirm.
In blender 2.79 this used to work.
And it's broken since the early versions of 2.80
Added subscriber: @dr.sybren
The
finger1-1.R
bone is not connected to its parent. The IK section of the manual states:As far as I can see, this has been in the manual for three+ years.
The fact that something used to work in 2.79 is thus mere coincidence. You could argue that an unconnected chain shouldn't even be allowed, and that the user interface should show a warning about this, but that would be a new feature and not a bug fix.
Added subscriber: @vasiln
@dr.sybren Please take another look. The issues remain if you connect finger1-1.R to its parent. If you need, I've done this for you in the attached file.
Note the behavior in the file: moving the IK target for the thumb isn't a problem, but moving the IK target for the hand leads to the thumb becoming disconnected.
In playing with this trying to troubleshoot BlenderAmateur's problem, I noticed some weird twitchy behavior that looks like Blender's behavior when faced with dependency loops, although the console shows none. The IKs seem to fighting rather than equally contributing, with whichever being manipulated most recently taking precedence. Given this and when the issue arose, I would suspect a bug in the dependency code.
rig_support_blender2_81_16(1).blend
And, in anticipation....
allconn.blend
All bones connected (about three seconds of work), issue persists. Tested in 2.81 release, 2.81a release, 2.82 beta hash
0ef881cc57
, 2.83 alpha hashf6aac92ab8
.Sorry, every time I type those hashes it does that inappropriate automatic markup, don't know how to tell it not to do that.
I also hope you can take a new look and consider what Nathan is writing.
Added subscribers: @Mets, @angavrilov
That's not inappropriate, that's a link to the actual commit. Very helpful for us.
We always consider what people are writing.
Thanks for that.
This isn't a dependency cycle, but that doesn't necessarily mean it's a supported situation. I've discussed this with our in-house rigger @Mets and he confirmed that two IK constraints influencing the same bone is not a good idea. @angavrilov do you know whether this was ever officially supported?
Changed status from 'Archived' to: 'Confirmed'
Added subscriber: @brecht
Checked with @brecht, and this is supposed to work indeed.
Child bones doesn’t follow parent when setting IK and chain length to a specific valueto Multiple IK chains influencing the same bone don't workI'm still trying to get a grip on what is supported and what is not. Here is a simple test file made in Blender 2.79b:
simple_279.blend
This file has two chains, and the left/right tip bones are IK-targeted to the toruses. As long as both IK chains are equally long (in this case 3, left image), it all works fine. However, when one chain ends in the middle of the other chain (in this case 3 and 4 for resp. the left and right bone, right image) things also break in 2.79b:
Opening the above file in current master (
2e9d5ba211
) also works fine:@brecht can you shed some light on what is actually supported and what isn't?
Bone parenting should never break like that, so this means there is a bug in 2.79 too.
The IK solver does not support a way to limit the influence of an IK constraint within an tree structure, it will always go all the way to the root of the tree structure. So I think the fix for this is automatically increasing the length of the shorter chain internally, so it goes up to the same root bone.
Actually I'm not sure about the solution of making the chain lengths the same. In the
file there is useful behavior without that. I believe evaluating it as two separate IK chains one after the other like that was an intentional feature.The problem in
is in the new dependency graph, if you use--enable-new-depsgraph
in 2.79 it fails as well. Seems like a missing dependency, where it's re-evaluating only one of the two required IK chains when moving thewristIK
object.The case in
simple_279.blend
is a bit different in that there is no obvious order in which to evaluate the two IK chains like there is inrig_support_blender2_79.blend
. So for that case it probably still makes sense to treat it like a single tree structure, though it's not as important to fix since it's easy to solve manually by tweaking the chain lengths.I think the most important thing is to fix what seems to be a missing dependency for the
case.@dr.sybren
Markup on the hashes is now gone, but I still have the original page up; on that page, it links not to a build for me, but to a particular issue. First links to Fix #71620: broken particle collisions due to
0666ece2e2
( https://developer.blender.org/rB0ef881cc57829471c441367ada6bf88119eaf26a ) which, of course, is not relevant to this issue. But of course it doesn't matter, if it links you to what you want, I'll continue to post hashes in the same way in future comments. Just offering because whatever behavior is going on might lead to users posting fewer hashes than they otherwise would, and of course hashes are going to be useful to y'all. (And because there might be some back-linking code setup that joins unrelated issues inappropriately, confusing folks incl. devs.)I see where the confusion comes from, I agree it's not that clear. It is a particular revision in Git, which fixes that particular issue. And yes, it does sometimes cause links between unrelated things.
This issue was referenced by
87b551e836
Added subscribers: @gentleclockdivider, @Sergey, @SimpleBone, @ZedDB
Added subscribers: @ecv, @JoshuaLeung
Added subscribers: @SidneyMoraesJr, @ErikFernandes, @GaiaClary
Hello. I was checking the related task and I see it is marked as resolved, but I did a simple test using today's build and the bug still there:
@SidneyMoraesJr That seems to be a different issue. Let's continue at #67232.
Ok. Thank you.
