Particle System Material preview error #73092
Reference: blender/blender#73092
blender_system_info.txt
blender_debug_output.txt
Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.87
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
f1aa4d18d4
The material preview viewport fails to display material on any object when there is a hair particle system present using textured objects or collections as the particles. The error is not present in blender 2.80
I do not believe this is a resource issue as blender can display the particle system when you very first create it and with one of the workarounds bellow without and issue.
Re-open file and everything present as all white or all black.
Workarounds
Opening another file without a particle system, previewing material in the viewport and then switching back to the original file without ever closing blender. Alternatively setting the viewport display particles to 0% then back to 100% works sometimes.
More info
Disabling Shader caching in Nvidia control panel did nothing.
A fresh install of blender did not resolve the problem.
The problem persisted from a file created on one machine and opened on another.
Files packed into the .blend and Unpacked made no difference.
Error v4.blend
blender_280_debug_output.txt
Added subscriber: @awils27
#70088 was marked as duplicate of this issue
Material Preview viewport Particle System Errorto Particle System Material preview errorAdded subscriber: @iss
I can not reproduce this in 2.83
Is this still an issue with latest build? https://builder.blender.org/download/
I can still recreate this issue in the blender 2.83 alpha.
Also using smaller resolution textures does not make a difference.
Here is a video of the steps I took to create the problem.
Blender Problem v2.mp4
I see you used drag&drop to add image texture. Can you verify, that when you re-open the file, you can see texture in image editor?
Or re-check this with generated texture?
Using a generated texture such as the noise texture node does not create this issue. Setting the viewport so that the image texture opens with the file still causes the issue. Finally manipulating the 3d viewports size in any way seems to fix the problem.
Blender problem v3.mp4
I can confirm now, I didn't change particle count to 4000, so it was OK initially
Added subscribers: @PaulHartsuyker, @lichtwerk
Closed as duplicate of #74302
