Rigify generate has naming consistency issues #73114
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
1 Participants
Reference: blender/blender-addons#73114
Broken:
2.81a release
Rigify generate naming issues
• Add a Basic Human metarig from add menu.
• Go into Advanced Option in Armature's generate panel and set it to new.
• fill the name field with anything you like (for example: CH-GUY_rig)
• click on generate
the resulting rig will be named accordingly to the input field but some naming issues will raise on widgets and python rig ui as follows:
rig name: CH-GUY_rig
python ui name: CH-GUY_rig_rig_ui.py
widgets main object parent: WGTS_CH-GUY_rig
widget objects: WGT-CH-GUY_rig_(bonename)
all names should follow same rule, so that
will accordingly set
python ui name: CH-GUY_rig_ui.py (this was already reported and noticed in #71678
widget objects: WGT_CH-GUY_rig_(bonename)
Added subscriber: @icappiello
another naming issue is related to overwrite option.
If in overwrite a new name is set (this option is often used to rename final rig after few raw generate tests) the tool work as expected and renames the selected rig and its correspondent python ui, but instead of renaming widget it creates a new set of widgets.
Also the widget collection should append or prepend the rig name. If not, when linking multiple characters the collection with same name will be renamed to .001 .002 and so on.
