Blender hard crashes on accessing particle uv_on_emitter
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.28
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash: rBf1aa4d18d49d
uv_on_emitter access crashes Blender
Open the attached file, and run the script.
Doesn't look like you did anything wrong. The uv_on_emitter function seems to cause a segmentation fault. Here's the backtrace:
# Blender 2.81 (sub 16), Commit date: 2019-12-04 11:32, Hash f1aa4d18d49d
# backtrace
blender(BLI_system_backtrace+0x1d) [0x14ee84d]
blender() [0x12cbb79]
/lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7fd0cfc894b0]
blender(CustomData_get_layer_index+0x3) [0x133c2c3]
blender(CustomData_has_layer+0x9) [0x133cb49]
blender() [0x163dfe0]
blender(RNA_function_call+0x12) [0x15a1742]
blender() [0x156ccca]
blender(_PyObject_FastCallKeywords+0x104) [0x18daaf4]
blender(_PyEval_EvalFrameDefault+0x2de5) [0x12c1d55]
blender(_PyEval_EvalCodeWithName+0xadc) [0x198c36c]
blender(PyEval_EvalCodeEx+0x3e) [0x198c49e]
blender(PyEval_EvalCode+0x1b) [0x198c4cb]
blender() [0x156330c]
blender() [0x3184a6e]
blender() [0x16a2f3b]
blender() [0x16a31a7]
blender(WM_operator_name_call_ptr+0x1a) [0x16a35aa]
blender() [0x2dde7a2]
blender() [0x2deda55]
blender() [0x16a5de3]
blender() [0x16a7e9c]
blender(wm_event_do_handlers+0x312) [0x16a8572]
blender(WM_main+0x20) [0x169dcd0]
blender(main+0x2fe) [0x1237f7e]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fd0cfc74830]
blender() [0x12c849c]
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Wed, Jan 15, 6:28 PM
Germano Cavalcante (mano-wii) triaged this task as Low priority.
I can confirm.
The crash happens because, in C, modifier->mesh_final it is NULL.
Apparently this only happens when the modifier is obtained through an unevaluated (original) object.
Which in this case was in this line:
source_mod = source_ob.modifiers[0]
Rewriting the script like this allows you to get the modifiers of the evaluated object, thus avoiding the crash.
import bpy
depsgraph = bpy.context.view_layer.depsgraph
source_ob_orig = bpy.context.selected_objects[0]
source_ob_eval = depsgraph.id_eval_get(source_ob_orig)
print(source_ob_eval.name)
source_psys = source_ob_eval.particle_systems[0]
print(source_psys.name, len(source_psys.particles))
source_mod = source_ob_eval.modifiers[0]
print(source_mod.name)
for prt in source_psys.particles:
    print(dir(prt))
    print(prt.uv_on_emitter(modifier=source_mod))
But a crash should never happen. So I wonder if source_ob_eval.modifiers[0] should be allowed for original objects.
Thank you guys! I'll use the evaluated object instead. Glad that it's still flagged to fix the crashing result.
