Ctrl-Z in Weight Paint Mode #73193
Reference: blender/blender#73193
Graphics card: GeForce GTX 1660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
f1aa4d18d4
Ctrl-Z didn't work in Weight Paint Mode
Added subscriber: @CaboomTaxi
Added subscriber: @lichtwerk
Cannot reproduce, could you share your .blend file?
Also:
Sorry, i can't upload scene where i found this bug.
But I managed to repeat it on cube (add scene).
Cube_With_Erorr_1.blend
Video: https://www.youtube.com/watch?v=tAQRlllIRk8
does this still happen whith Factory defaults? (Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue)
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @WilliamReynish
Hm, still cannot reproduce.
What I noticed though is that you have the armature first in your selection, then the cube.
That results in you actually parenting the armature to the cube [with no armature modifier on the cube then, automatic weights also not really taking place...]
(find a bit distracting that this is actually always in the menu now @WilliamReynish -- if you use Ctrl+P this is bit more sensitive to the selection order and wont let you do that, but that is a bit of a different story...)
Anyways, could you try if the reported issue about Ctrl+Z actually happens when you first select the cube, then select the armature, and go on from there?
Added subscriber: @iss
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
@CaboomTaxi Can you check if this happens with 2.82 version? https://www.blender.org/download/
Hey guys!
Sorry, i\ll have time to check this issue in 2.82, tomorrow.
Since 2.83 has been released, please check that as well if 2.82 is still buggy.
Ok, will check in 2.83!
Added subscriber: @lOMH_Dev
hey guys habe the same issue in 2.90 it seams like it couses the mesh and armature to scale to a realy small size.
did someone figured out how to revers this aktion?
I am not sure if this is same issue. Please create new report.
