Pls fix Blender #73307
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#73307
Operating system: Win 10
Graphics card: Geforce gtx 1660 dual evo
all uppdateds installed
Broken: 2.8 2.79 doesn't work ether.
(example: 2.79b release)
Worked: Not
Short description of error Command flashes once with gray window in the back then Shuts off.....
Please some one fix Blender. I have paid 1600 euro for a new PC for the purpoce of learning Blender
Please someone fix blender.
Added subscriber: @Nightcrawler
Added subscriber: @Pasang
The devs can't really help you with such minimal infos !
Are you implying that blender doesn't open or that it crashes?
Please provide a blend file and simple steps to recreate the issue. Also try running blender from blender_debug_log file and attach the log files.
Added subscriber: @ideasman42
This report does not contain all the requested information, which is required for us to investigate the issue. Please submit a new report and carefully follow the instructions.
Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem (unless it happens in the default startup file).
Added subscribers: @EAW, @ankitm
@EAW you could close this as dupe of https://developer.blender.org/T73308 if they are really the same ?
