Grease Pencil: Strength sculpt brush does not work at small sizes, since 2.81
Closed, ResolvedPublicBUG
Graphics card: AMD Radeon HD 5700 Series ATI Technologies Inc. 4.5.13417 Core Profile Context 15.301.1901.0
Broken: version: 2.82 (sub 5), branch: master, commit date: 2019-12-13 20:35, hash: rBc6ba94133934
Worked: 2.80
The "Strength" brush in Grease Pencil Sculpt Mode does not work unless the radius is turned very high.
This bug seems to be specific to my setup in some way, as other users I've asked don't encounter it.
I first noticed this bug using an early build of 2.81. The strength sculpt tool worked properly in 2.80. I tried the current beta of 2.82 and the 2.83, and the bug still persists
  1. Create a new "2D Animation" file
  2. Draw a Grease Pencil line
  3. Go into Grease Pencil sculpt mode
  4. Select the "Strength" tool
  5. Using various settings of brush strength, "add" or "substract", fall off or pressure, try sculpting the strength of the line drawn in 2.
  6. The strength (opacity) should barely change, mostly not at all.
  7. Turn up the brush size to something around 300px
  8. Try sculpting the strength of the line. It should now react as expected.
Here are a few files I saved testing the bug. The first file is from 2.80 where Strength sculpt worked as expected, the others are from later versions where the bug occurs:
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Jan 23 2020, 12:44 PM
Tested 2.80 and 2.81 file and got same behavior
@Lionel Fiévet (Nelfie) can you click on File > Defaults > Load Factory Settings and test your files?
Antonio Vazquez (antoniov) changed the task status from Needs Information from User to Confirmed.Jan 23 2020, 4:47 PM
Antonio Vazquez (antoniov) claimed this task.
Antonio Vazquez (antoniov) changed the subtype of this task from "Report" to "Bug".
