Adding very weak emissions to the scene weakens the highlights in cycles render #73328
5 Participants
Reference: blender/blender#73328
Operating system:macOS 10.15.2
Graphics card:Radeon Pro 580X 8 GB
Broken:2.82 Beta 2020-01-22 12:36 Hash:a60a623a1ac5
Light_test.mp4
Uploaded blend file has strong emission, very weak emission and background light.
Very weak emissions have keyframes, 1 frame has a value of 0, and 2 frame have a value of 0.001.
Comparing the rendered images shows that the highlights of the 2 frame is weaker than the highlights of the 1 frame.
It seems strange that the highlights get weaker if you add a very weak emission that does not affect the scene.
Not included in the video, but placing very weak emissions close to strong emissions has the same effect.
If you add weak radiation, I think it will be a bit brighter, but the result will be darker.
Light_test.blend
Added subscriber: @cubimation
Added subscriber: @MarcinTwarowski
It would be easier to test it if you simplified that scene. There are 88 thousand objects. I tried to delete the layer with those cubes but it takes Blender forever.
I upload a light sized file
Light_test2.blend
Added subscriber: @mano-wii
I can confirm.
Operating system: Windows-10-10.0.18941 64 Bits
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13559 Core Profile Context 26.20.12028.2
The problem is seen in both GPU and CPU
Added subscriber: @EAW
I don't think that this is a bug, but a known limitation of Monte Carlo ray tracing.
Cycles has 2 sampling methods.
You have a light with a strength of 678.4, the world background at 1, and then you add a light with a strength of 0.001. Frame 1: Ever pixel sample is either lit by the 678.4 light or the world background at 1, chosen at random. Frame 2: you add in another light source at 0.001. The result is that it will bring the overall lighting intensity down, because it is using up the random samples that would have gone to the other light sources.
If you switch to Branched Path Tracing, which takes all lights into account, you will see that the additional light makes the scene brighter.
Emissive materials have Multiple Importance Sampling on by default.
Turn off Multiple Importance Sampling for the 0.001 light, even when using Path Tracing, and Frame 1 & 2 are identical, as the 0.001 light is too minuscule to contribute any change.
Added subscriber: @brecht
Added subscriber: @Alaska
This appears to be the same issue as #97305 (As light object numbers increase, the indirect brightness of bright lights is decreased while indirect light clamping enabled - Cycles). I will merge these reports.
Closed as duplicate of #97305
