Material not rendered on mirrored object #73380
2 Participants
Reference: blender/blender#73380
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
f1aa4d18d4
Worked: (2.79) Also broken in 2.82 January 25/2020
When the material in the attached file is applied to a mirrored object the material does not render on the mirrored object.
Applying the mirror will make the material render. Changing the Multiply node connected to the Emission strength to an add node will cause the material to render. Different math functions produce results. Divide for example does not render.Material.blend
2.79 will render this material on mirrored objects.
Render the image in the attached file. Switch to rendered or material preview in Cycles or Evee.
Expectation would be the materials on mirrored objects would be identical to the object begin mirrored.
Added subscriber: @Scotty918
More information I simplified the material to what is shown in this image.
With this material using an add node both the object and the mirrored object render in cycles but not in eevee.
Added subscriber: @lateasusual
Not a bug.
In the example file you are using generated texture coordinates which are in object space and not mirrored. Applying the mirror modifier changes the generated texture space, and you can adjust it yourself in the mesh settings under "Texture Space"
EEVEE doesn't support using Emission shaders for volumetrics, use a Principled Volume BSDF node instead.
