GreasePencil Fill
Confirmed, NormalPublic
Operating system: Windows-10-10.0.15063-SP0 64 Bits
Graphics card: Quadro P5000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 382.59
Broken: version: 2.83 (sub 0), branch: master, commit date: 2020-01-12 16:27, hash: rBf6aac92ab828
Added a mesh and deleted the faces, converted to a curve then again to greasepencil, enabled the fill option to create a grease pencil cube. Fill doesn't work properly.
A{F8308036}
all default meshes don't fill properly when converted to a curve then greasepencil.
Add Cube --> Edit mode -->delete only faces --> convert to --> Curve from Mesh/text -->convert to --> grease pencil from curve --> material properties -->New --> surface-->enable fill--> Doesn't fill the 6 sides, it's a deformed fill.
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Wed, Jan 29, 5:30 PM
Don't think this can be considered a bug, just a Know Limitation. Really, these tools are not designed to do this.
The conversion from curves to grease pencil is not done by faces or any other information, just curves. I have tested, and after the conversion you get 4 strokes.
If you test the first step when the mesh is converted to curves, you will see 4 curve segments (splines) too.
As you can see, the filling by faces is impossible. If you want faces, you must convert face by face.
