environment pass is occluded by geometry making it unusuable with a shadowcatcher #73497
Reference: blender/blender#73497
Operating system: Windows-10-10.0.17134-SP0 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
Broken: version: 2.83 (sub 1), branch: master, commit date: 2020-01-24 11:49, hash:
11df5443e5
Worked: unsure if ever
open attached .blend, go to compositing workspace, hit f12, when finished use the split viewer factor to slide between the image and the environment pass.
Perhaps the transparency section needs an additional 'shadow catchers are transparent'.......although that wouldn't make much sense as shadow catchers should always be transparent. Regardless, the environment pass definitely shouldn't contain any geometry information. Is there ever a scenario where you'd want the environment AOV to be jet black where the 3d objects are located?
environment alpha bug.blend
Added subscriber: @3di
Added subscribers: @Sergey, @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Can confirm the behavior
This might very well not be a bug, but a limitation instead.
#55916 (Cycles Shadow Catcher Creating Multiple Shadows) seems related.
However, I would also expect (in an ideal world) to somehow not have the shadow catcher show up in that pass [this one at least, havent checked others...]
Maybe @Sergey Sharybin (sergey) wants to share his wisdom?
Worth mentioning that it’s not just the shadow catcher that shows up in the pass, it’s all objects.
Not sure that other objects are an issue? Since the recommended way to combine the passes is to
ADD
environment (or how are you comping this?):https://docs.blender.org/manual/en/dev/render/layers/passes.html#combining
Check the file I sent and use the viewer to look at the envinroment pass on its own prior to any comping.
I should point out that the only reason that the glass data isn't included in the environment pass is because I used the transparent glass option in the render settings's film panel.
using add isn't a very good solution as it wont work in all circumstances where there's alpha in the foreground, or if you want to move/scale the environment in comp etc.
I would stick discussion to the shadow catcher here [since ADD is the recommended way, Eevee will do it the same afaict, if this should really be changed, it would turn this report into a design kind of discussion...]
For me, the shadow catcher [and only that for the moment] is a pretty valid point, leaning towards calling this a bug...
For other objects and the environment pass, I would suggest heading over to https://devtalk.blender.org/ and start a discussion there...
But there’s nothing wrong with the shadow catcher, the bug is with ALL objects masking the environment pass. There is no situation where this is needed, and it’s meaning you have to render twice (rendering the environment pass in its own view layer with everything else hidden)
Added subscriber: @Jeroen-Bakker
@3di that is by design as the environment is an additive pass that is applied in the end of the composite. If you want a full environment pass you need to setup a specific view layer for it. See https://docs.blender.org/manual/en/dev/render/layers/passes.html#cycles
Added subscriber: @brecht
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
This is indeed the design, feedback on that is outside the scope of the bug tracker.
@brecht: talked to @Jeroen-Bakker on #blendercoders, and the point about about the shadowcatcher (not other objects) is valid, no?
It's a valid feature request to want an environment pass that you can use for compositing shadow catchers onto, but not a bug in my opinion. That was never the intent behind the original implementation of the environment pass and shadow catcher.
If you want to layer the render to recomposite it, that's what render layers are designed for. The light passes are there to decompose the combined render into separate components, they will not render anything that isn't already in the combined pass.
Changed status from 'Archived' to: 'Confirmed'
OKi, thx checking again
Thanks for looking at this guys.
It's worth mentioning that for a more robust compositing workflow (not just recreating a render from it's passes), it's absolutely necessary to be able to produce AOV's which are not masked by scene geometry. Especially for custom AOV's. I'll add it on right click select and hope for the best.
