Eevee spotlight clipping through solid objects while using Principled Volume #73551
6 Participants
Reference: blender/blender#73551
Operating system:
Graphics card:
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: (optional)
system-info.txt
Volumetric_with_spotLight.blend
If you use a spotlight inside a solid object (Simulating a lamp reflector) and you use principled volume on your scene when you render,
you can see the light in the other side of object. Like as an interference.
You can reproduce in the blender file attached.
Added subscriber: @MarceloPereiradeFreitas
#96257 was marked as duplicate of this issue
Added subscribers: @fclem, @Jeroen-Bakker
This is related to a known limitation of eevee https://docs.blender.org/manual/en/latest/render/eevee/limitations.html
As the implementation is working as designed this is not considered a bug. @fclem Do you want this to be marked as a
orInvalid
?Changed status from 'Confirmed' to: 'Archived'
It is a limitation because the step size is way too high (i.e: "Sample" is way too low compared to "Start", "End" and "Distribution" is tuned too far from 1.0) so light from further froxels (frustum aligned voxels) bleeds light onto closer geometry because of linear interpolation.
Added subscribers: @joaulo, @PratikPB2123
