Material Library VX errors #73571
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#73571
Operating system: Windows-10-10.0.19035 64 Bits
Graphics card: GeForce GT 730/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.50
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
blender/blender@f1aa4d18d4
Addon Information
Name: Material Library (0, 5, 9)
Author: Mackraken (mackraken2023@hotmail.com)
After applying 3 materials from this library, I start getting errors and can no longer use any materials, including previously used ones, until I remove and re-add the add-on.
After three, you should start getting a Traceback error that will occur for any material, including the ones you started with.
At first I thought it might be because I launch Blender off on my Google Drive, but after doing the .zip extraction to my local drive I was still having the problem.
Added subscriber: @Durghan
Added subscriber: @lichtwerk
Cannot really reproduce here (not exactly sure if I am doing it right/wrong though...)
What I did was:
add 4 new material slots to the default cube
add 4 new materials
in the Material Library VX panel, chose Cycles Materials
for the above new materials each, chose one of the Cycles Materials [e.g. Car Paint, Apple Juice, ...] and hit apply To Selected
Does the above fail for you?
If your reproduction steps are different: please explain exactly how you "add various materials to the default cube object"
Added subscriber: @Blendify
Changed status from 'Needs User Info' to: 'Resolved'
Hi. Sorry! My mistake. When Philipp commented, I received an email and attempted to reply to the email without thinking about this page. So when the email came back as undeliverable I simply gave up because I didn't think I'd be able to get ahold of anyone. Now that I received the task closed notice I see now where I went wrong.
So, I went in and tested it out and I was able to apply every texture, and several of them multiple times without any problems. So yes, I believe the issue is gone now. At least as of 2.82 anyways.
Thank you.
Glad to hear :)
