UI: Zooming out in any editor/area its a lot faster than zooming in (exept the 3D view)
Closed, ResolvedPublicTO DO
Operating system: Linux-5.3.0-29-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.83 (sub 2), branch: master, commit date: 2020-02-03 17:41, hash: rB03a29090b57d
Worked: never worked properly in 2.8x
Using Ctrl+MiddleMB we can zoom in and out in a lot of areas from editors to toolbars, however zooming out goes a lot faster than zooming in, for example the 3D view works fine but not the toolbars or properties shelf.
Sorry for the video but i don't have a better way to explain it
https://youtu.be/WYdW96oN7z0
Try to Zoom in any toolbar or the properties editor using Ctrl+mmb and look carefully how much do you move the mouse up and down.
Nahuel Belich (belich) renamed this task from UI: Zooming out in any editor/are its a lot faster than zooming in to UI: Zooming out in any editor/area its a lot faster than zooming in (exept the 3D view).Feb 4 2020, 12:51 AM
Nahuel Belich (belich) updated the task description. (Show Details)
Campbell Barton (campbellbarton) changed the task status from Needs Triage to Confirmed.Feb 4 2020, 2:54 AM
Campbell Barton (campbellbarton) triaged this task as Low priority.
Campbell Barton (campbellbarton) changed the subtype of this task from "Report" to "To Do".Feb 4 2020, 2:57 AM
Also there seems to be no way to reset the zoom for many editor panels
You should be able to reset the zoom with Home
Changing the zoom axis from vertical to horizontal helps but that is not as comfortable in the 3d viewport.
This issues depends on the aspect ratio of the editor, so if you have a square view, the zoom in and out is quite uniform.
But if the view is rectangular then zoom in is much slower than out.
I tried this quick hack and it solved the issues:
diff --git a/source/blender/editors/interface/view2d_ops.c b/source/blender/editors/interface/view2d_ops.c
index 5cf7cb4e7c4..88b488087c1 100644
--- a/source/blender/editors/interface/view2d_ops.c
+++ b/source/blender/editors/interface/view2d_ops.c
@@ -1081,11 +1081,13 @@ static int view_zoomdrag_invoke(bContext *C, wmOperator *op, const wmEvent *even
     /* support trackpad zoom to always zoom entirely - the v2d code uses portrait or
      * landscape exceptions */
     if (v2d->keepzoom & V2D_KEEPASPECT) {
+      const float ratio = BLI_rctf_size_x(&v2d->cur) / BLI_rctf_size_y(&v2d->cur);
       if (fabsf(dx) > fabsf(dy)) {
-        dy = dx;
+        dy = dx / ratio;
       else {
-        dx = dy;
+        dx = dy * ratio;
     RNA_float_set(op->ptr, "deltax", dx);
@@ -1214,11 +1216,13 @@ static int view_zoomdrag_modal(bContext *C, wmOperator *op, const wmEvent *event
     /* support zoom to always zoom entirely - the v2d code uses portrait or
+      float ratio = BLI_rctf_size_x(&v2d->cur) / BLI_rctf_size_y(&v2d->cur);
-        dy = dx;
+        dy = dx / ratio;
       else {
-        dx = dy;
+        dx = dy * ratio;
However MOUSEZOOM (trackpad pinch) is very slow.
Related to this issue, zooming in and out in the Cycles node editor is really slow with pinch gesture on a Mac trackpad. Zooming in is painfully slow and zooming out is somewhat okay, but could still be way faster without being uncontrollably fast.
Hi , I am new to blender devlopment and want to contribute . So , I would like to solve this issue .So can somebody please provide me with some more information about the issue.
Thank You
Joel Hjerten (JeloSWE) changed the task status from Resolved to Archived.EditedJan 21 2021, 4:41 PM
The issue still persist in 2.9 (portable version) https://developer.blender.org/T84914
@Robert Kirberich (robert) Guetzkow (rjg)
@Campbell Barton (campbellbarton)
It's not resolved and has to be reopened for fixing again.
@Robert Kirberich (robert) Kirberich (robert) Guetzkow (rjg) please reopen this task, the bug still remains in 2.91 Portable.
@Joel Hjerten (JeloSWE) You would need to test the current version under development, daily build of version 2.93, that includes the patch. If the problem still occurs in that version, please create a new bug report.
Tagging on this platforms works by using @ followed by the username. So to notify me you would type @rjg.
Robert Guetzkow (rjg) changed the task status from Archived to Resolved.Jan 22 2021, 2:39 PM
