GPU Compute option for cycles incorrectly disabled. #73676
5 Participants
Reference: blender/blender#73676
Operating system:
Windows 10 Professional
Graphics card:
Nvidia GTX 1080
Broken: 2.82 Beta (all versions going back at least a month)
Worked: 2.81a
GPU Compute is greyed out in the cycles render properties and rendering is done by the CPU. If I go into Preferences -> System, add my CPU as a CUDA target then the GPU compute option is no longer greyed out. I then untick the CPU and rendering is then done on the GPU instead of the CPU. I need to do this process every time I restart Blender in order to use GPU rendering.
This happens in every system file and on every version of 2.82. Reproduction steps are to start with the default scene, select Cycles as renderer. GPU compute is disabled.
Added subscriber: @huttbutter
Added subscriber: @rjg
You shouldn't have to enable / disable the CPU in the CUDA tab if your goal it to render on the GPU.
GPU is being correctly identified as a CUDA device in preferences, but not in Render Properties.
And it definitely is running renders on the GPU, obviously there's a huge speed difference and I can see the compute core on the GPU going to 100% in windows task manager. :)
What I meant was that the CUDA tab is still selected (highlighted in blue) and that you're not switching to a different tab (None, OpenCL, Optix).
Does this issue only affect your selection for GPU rendering or are other preferences also not saved/applied correctly?
Oh, right, yes then I'm still on the CUDA tab. I've not seen any other problems with preferences. As far as I can tell the preference IS being set (and, in fact, automatically detected correctly), but perhaps it's not got the right value when read by Render Properties initially. Hmm.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @MistahX99
Same card same problem although I'm on 2.80
Added subscriber: @S.Fairfoot
This issue is present on my system as well using a GTx 1070.
Did a driver update on the GPU and still need to disable the CPU in preferences before the GPU option in cycles is no longer greyed out.
Before most recent updates of GPU and other system updates together with a new SSD installation, this issue was not present.
Everyone affected by this issue, please try if it is still present in Blender 2.83 starting with the factory default settings.
Added subscriber: @Jeroen-Bakker
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
There is no mentioning of any driver versions in this report. Can anyone go to Blender's Help menu and Press Save System Info... This will generate a file with the drivers versions and other related info what could perhaps find the cause. Please upload that file here.
