Memory leak when linking Grease Pencil objects to scene
Confirmed, NormalPublicBUG
Operating system: Linux-5.3.0-7625-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.44
Broken: version: 2.83 (sub 2), branch: master, commit date: 2020-02-07 22:49, hash: rBa010d9720455
Memory leak after linking Grease Pencil objects to scene. Seems to be happening when the scene updates while editing an object or playing animation or just moving viewport camera.
  1. open attached file
  1. play animation
  2. look at memory usage
Ankit (ankitm) added a subscriber: Ankit (ankitm).EditedSun, Feb 9, 12:36 AM
On Operating system: Darwin-18.6.0-x86_64-i386-64bit 64 Bits, I get:
Read blend: /Users/ankit/Downloads/memory_leak.blend
read file /Users/ankit/Downloads/memory_leak.blend
  Version 283 sub 2 date 2020-02-07 22:49 hash a010d9720455
Info: Read packed library:  '//../../../media/dmitriy/Main2/Alyx_Unreal4/GAMEFILES_NEW/Other/Concept Art/CA v2/ca_suit1.blend', parent '<direct>'
Segmentation fault: 11
So please add a portable file.
Ankit (ankitm) changed the task status from Needs Triage to Needs Information from User.Sun, Feb 9, 12:37 AM
Ray molenkamp (LazyDodo) changed the task status from Needs Information from User to Confirmed.Sun, Feb 9, 1:44 AM
most of it seems to leak in gpencil_populate_datablock
Line #, Process, Type, Stack, Count, Impacting Size (B), Size (MB)
23, , ,   |    |    |    |    |    |    |- blender.exe!drw_engines_cache_populate, 3709, 17,070,775, 16.280
24, , ,   |    |    |    |    |    |    |    blender.exe!GPENCIL_cache_populate, 3709, 17,070,775, 16.280
25, , ,   |    |    |    |    |    |    |    blender.exe!gpencil_add_draw_data, 3709, 17,070,775, 16.280
26, , ,   |    |    |    |    |    |    |    blender.exe!gpencil_populate_datablock, 3709, 17,070,775, 16.280
@Ray molenkamp (LazyDodo) This is going to be totally changed in the refactor, so we need test if the leak is in greasepencil-refactor branch
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".Wed, Feb 19, 2:10 PM
Tested with refactored version and I'm unable to detect any memory leak, so we can consider as solved in the refactored code.
