Images appended from disk do not have data #73761
6 Participants
Reference: blender/blender#73761
Operating system: Broken on Mac OS and Windows 10
Graphics card: --likely irrelevant--
Broken: 2.83 (sub 9), branch: master, commit date: 2020-03-14 18:05, hash:
a210b8297f
Worked: 2.81a
Appended images from disk do not have data, and it seems the only way to load the data is to open it in the 'Image'/'UV' editor. This is not a solution, however, because I need to append an image and then access the image data via a script running on a background instance of Blender.
I believe the image should automatically have data when appended, but if not, there should at least be some way to load the image data via Python API.
False
, and theim.reload()
andim.update()
image utility functions will not change this.Added subscriber: @bblanimation
#86777 was marked as duplicate of this issue
Added subscriber: @ideasman42
Tested on Linux, both files are the same size. Maybe it's spesific to windows.
Writing images to library files in temp directory results in empty datato Writing images to library files in temp directory results in empty data on WIN32Ah, I have new information.
The problem is not actually on writing the files - the files are the same size for me as well. The problem is in appending the data. If I take the library file from my desktop and copy it into my Temp folder, the image appends without data, but if I place it back on my desktop, the image appends fine with all of its data.
I've also confirmed the same issue is present on MacOS.
Added subscriber: @mano-wii
I also cannot reproduce the problem. Am I doing something wrong?
Operating system: Windows-10-10.0.18941 64 Bits
Perhaps it has something to do with the image file I'm using? Here's the image file:
Also could not reproduce the problem with the image attached.
This can be a problem when reading the directory (special characters or something).
Which directory is printed in
print(path2)
?I won't have access to my Windows machine at the moment, but I believe it was something like this:
C:\Users\chris101343\AppData\Local\Temp
I did notice that, for my Mac at least, the problem doesn't seem to happen when run from default startup – only when run using my bare-bones test file. I've attached the file below.
texture_issue.blend
I have a bit more information as I continue to investigate:
The problem seems to be that for some reason, my image does not have data. If I type the following into the console:
It prints:
I imagine this has something to do with why the image does not write correctly. Perhaps the image is not properly loaded when opening the blend file?
Writing images to library files in temp directory results in empty data on WIN32to Images appended from disk do not have dataChanged status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I've updated the title and description to reflect the state of this bug in 2.83 – The steps to reproduce the error should be very clear.
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
Trying the script here,
has_data
also returnsFalse
if it is not loaded in an editor.Seeing the description of
has_data
, it is said:So the image was simply not loaded into memory.
I don't see why that would be a bug.
For questions about the python API, you can try: https://blender.stackexchange.com/
The issue is not with the
has_data
property. The issue is that images not yet loaded in memory do not write to disk correctly withbpy.data.libraries.write()
, which is a bug. At the very least, an error should be thrown if the image data has not been loaded to memory, rather than writing bad data to a file.Added subscriber: @brecht
By default, the image datablock is just a reference to an image file on disk. What
has_data
tells you is if the image pixels are cached in memory, the image file on disk is still where the permanent storage is.If you want pixels to be written into a .blend file, you need to pack the image.
Added subscribers: @Andrew_D-1, @lichtwerk
