Workbench's X-ray not showing correctly #73765
Closed
opened 2020-02-12 18:37:40 +01:00 by ChristopherAnderssarian · 17 comments
Operating system: Windows 7
GPU: Radeon Vega 64, Divider version: 19.12.2
CPU: Intel Core i7-5960X
Blender Version(s)
(listed are versions tested)
Working: None
Broken: blender-2.80-f6cb5f54494e-windows64 (official release)
Broken: blender-2.81-26bd5ebd42-windows64 (official release)
Broken: blender-2.82-fa5e28ab08c7-windows64 (build bot)
Broken: blender-2.83-9d90cad3ed39-windows64 (build bot)
Broken: blender-2.83-7e99e396a999-windows64 (build bot)
The value of X-ray in this project is 0.001, the viewport is not showing the correct result.
Viewport Render result (incorrect) Render result (correct)
Workbench.blend
  • Open File
  • In 3D view click View > Viewport Render Image
**System Information** Operating system: Windows 7 GPU: Radeon Vega 64, Divider version: 19.12.2 CPU: Intel Core i7-5960X **Blender Version(s)** *(listed are versions tested)* Working: None Broken: `blender-2.80-f6cb5f54494e-windows64` (official release) Broken: `blender-2.81-26bd5ebd42-windows64` (official release) Broken: `blender-2.82-fa5e28ab08c7-windows64` (build bot) Broken: `blender-2.83-9d90cad3ed39-windows64` (build bot) Broken: `blender-2.83-7e99e396a999-windows64` (build bot) **Short description of error** The value of X-ray in this project is 0.001, the viewport is not showing the correct result. | ![viewport render result.png](https://archive.blender.org/developer/F8336669/viewport_render_result.png) | ![untitled.png](https://archive.blender.org/developer/F8403810/untitled.png) | | -- | -- | | Viewport Render result (incorrect) | Render result (correct) | **Exact steps for others to reproduce the error** [Workbench.blend](https://archive.blender.org/developer/F8336656/Workbench.blend) - Open File - In 3D view click View > Viewport Render Image
Added subscriber: @ChristopherAnderssarian
Added subscriber: @iss
I've got this result, but I've had to render twice... version: 2.83 (sub 2), branch: master, commit date: 2020-02-13 17:12, hash: b6572c5430
And with no atrifacts on version: 2.82 (sub 6), branch: master, commit date: 2020-02-11 13:04, hash: 3dcddf83bf
Viewport render is not working for me at all
Can you try to render twice?
I've got this result, but I've had to render twice... version: 2.83 (sub 2), branch: master, commit date: 2020-02-13 17:12, hash: `b6572c5430` ![a.png](https://archive.blender.org/developer/F8338147/a.png) And with no atrifacts on version: 2.82 (sub 6), branch: master, commit date: 2020-02-11 13:04, hash: `3dcddf83bf` ![2.82.png](https://archive.blender.org/developer/F8338160/2.82.png) Viewport render is not working for me at all Can you try to render twice?
What do you see for rendered viewport? Your images look to be F12 renders... the issue is rendered viewport shading.
What did you get on your first render?
Could you elaborate?
What do you see for rendered viewport? Your images look to be F12 renders... the issue is rendered viewport shading. >I've got this result, but I've had to render twice... What did you get on your first render? >Viewport render is not working for me at all Could you elaborate?
Empty image.
I have to hit render (F12) twice, when I open file. After that rendering works consistently (produces some image)
Every time I hit F11 and I get empty image.
> In #73765#871192, @ChristopherAnderssarian wrote: > What do you see for rendered viewport? Your images look to be F12 renders... the issue is rendered viewport shading. > >>I've got this result, but I've had to render twice... > > What did you get on your first render? Empty image. I have to hit render (F12) twice, when I open file. After that rendering works consistently (produces some image) >>Viewport render is not working for me at all > > Could you elaborate? Every time I hit F11 and I get empty image.
Okay, try this:
  • Open .blend
  • Switch to rendered viewport shading
At which point I see this:
What do you see?
Okay, try this: - Open .blend - Switch to rendered viewport shading At which point I see this: ![snip.PNG](https://archive.blender.org/developer/F8338210/snip.PNG) What do you see?
I see same thing
I see same thing
Right, but when you F12 you don't see the cube. When you viewport render (shading) you see the cube, because x-ray doesn't work correctly in the viewport. See the problem?
I understand now, you didn't hit F11, you just made a screenshot..
Member
Added subscriber: @Jeroen-Bakker
Member
Changed status from 'Confirmed' to: 'Needs User Info'
Member
Can anybody update the description of this issue so it is easy for developers to reproduce.
I am not able to reproduce the issue, but that could also because of the missing information in the report.
Perhaps add a video would help.
Thanks
Can anybody update the description of this issue so it is easy for developers to reproduce. I am not able to reproduce the issue, but that could also because of the missing information in the report. Perhaps add a video would help. Thanks
@Jeroen-Bakker Sorry, I was a bit confused about this one, but it seems it has been resolved already
@ChristopherAnderssarian can you confirm it is resolved?
@Jeroen-Bakker Sorry, I was a bit confused about this one, but it seems it has been resolved already @ChristopherAnderssarian can you confirm it is resolved?
The problem was that X-Ray didn't show the same result in the Rendered viewport vs. F12.
But having said that blender-2.83-acab7450784a-windows64 works as expected.
Probably got fixed with D7060
The problem was that X-Ray didn't show the same result in the Rendered viewport vs. F12. But having said that `blender-2.83-acab7450784a-windows64` works as expected. Probably got fixed with [D7060](https://archive.blender.org/developer/D7060)
Member
Changed status from 'Needs User Info' to: 'Resolved'
Ankit Meel self-assigned this 2020-03-27 10:42:38 +01:00
Reference: blender/blender#73765
