Blender complains that it cannot find "stdosl.h", despite it existing at "/usr/share/OSL/shaders/stdosl.h" #73830
Reference: blender/blender#73830
Operating system: Arch Linux
Graphics card: RX 580
Broken:
df1e9b662b
, "Cleanup: Fix build warnings from OSL shader compilation"Worked:
6a28d14f72
, "Fix #73740: Auto-key "Only Available" de-selects f-curves"Short description of error
Blender cannot find "stdosl.h", even though it exists.
On Arch Linux, install openshadinglanguage, and then attempt to compile Blender master.
Other
Related: https://developer.blender.org/D6812
Upon examining the borked commit, I noticed this comment:
Unfortunately, there is no provided CMake option allowing a custom OSL_SHADER_DIR location to be set, as the current assumptions don't account for where packagers may place system files. In Arch Linux, the compiler is here, "/usr/bin/oslc", while the shader directory is here, "/usr/share/OSL/shaders".
Added subscriber: @KyleDeVir
Added subscribers: @LazyDodo, @brecht
@LazyDodo, probably we should improve
FindOpenShadingLanguage.cmake
to find the shaders directory.I'm not on linux so i can't really test this but can anyone give this a whirl?
CMake doesn't like it:
Syntax error in cmake code at
/tmp/makepkg/blender-git/src/blender/build_files/cmake/Modules/FindOpenShadingLanguage.cmake:93
when parsing string
${ENV{OSLHOME}}
Invalid character ('{') in a variable name: 'ENV'
build_files/cmake/platform/platform_unix.cmake:71 (find_package)
build_files/cmake/platform/platform_unix.cmake:248 (find_package_wrapper)
CMakeLists.txt:801 (include)
toss that one line for now then, just to see if it picks up your headers in /usr/share
Added subscriber: @grosgood
This bit me. Gentoo Linux here, with ##media-libs/osl-1.10.5## providing shaders in system folder ##/usr/include/OSL/shaders##
For what it is worth, my workaround:
- Define in build directory ##CMakeCache.txt## the symbol ## OSL_SHADER_DIR:PATH=/usr/include/OSL/shaders##
- Modified blender/intern/cycles/kernel/shaders/CMakeLists.txt:
TL;DR I added a second include directive so that the OSL compiler looks in the installed OSL shader directory as well as the specific blender build directory.
Haven't tested if this approach works beyond my peculiar little world. Hope it helps point the way to a more general solution.
[edit]
@KyleDeVir
Try: ##cmake ../blender -D OSL_SHADER_DIR:PATH=/usr/share/OSL/shaders##
Maybe substitute ##../blender## with the path to your blender source tree. In my case, the build directory is a co-directory of the source directory.
Your patch fails, sadly.
@LazyDodo It would probably be a good idea to allow packagers to set the
OSL_SHADER_DIR
variable themselves, as the comment in the OP states.Yet, I think you may have simply forgotten to offer that as a CMake option, as there's currently zero way to set it.
@LazyDodo Ah, I see... your patch had
/usr/share/osl
, when it should be/usr/share/OSL
, as most Linux filesystems are distinguish between lower and uppercase.Actually, no, nevermind, that fails, too...
Hmmmmm......
@KyleDeVir
Note that my workaround is peculiar to a Gentoo linux box; the steps need a certain amount of remapping to work on other distros. Fortunately, Arch is not that far removed from Gentoo.
In your case, introduce a CMake symbol via
Patch ##/intern/cycles/kernel/shaders/CMakeLists.txt## as indicated in my first comment
Probably be a good idea to create a working branch first to keep your git repository tidy
Then patch ##CMakeLists.txt##
This is just a Linux-centric workaround. Unfortunately, various Linux distros put the shader directory in various places. Witness Gentoo: ##/usr/include/OSL/shaders## vs. Arch: ##/usr/share/OSL/shaders##. It's an all-around PITA to deal with this. Probably, to duck this issue, is why blender developers from ages ago made their private copies, the issue that the good, brave @LazyDodo is trying to address.
Huh ~ it works, if I symlink
to/usr/shaders
. That's... something. Not what's needed, anyhow. :|@grosgood
Thanks! Will give it a try.
Yeah, your solution works. Cheers. :)
Great! Don't forget this is a hack - unofficial, unsupported, probably radioactive. If you've followed my suggestion of creating a local git branch ##osl_fix## to contain the patch, and you sit on the ##osl_fix## branch to do your builds, then you've got (just a little) extra work to keep ##osl_fix## aligned with ##master## whenever you perform ##make update##. See Creating Patches from Local Git Branches . The gist of it is: from ##osl_fix##: ##git checkout master##, ##make update##, ##git checkout osl_fix##, ##git rebase master##. When the fix for this lands in master, you can just checkout master and do the update, then abandon ##osl_fix:## ##git branch -D osl_fix##.
I manged to test some of this out on WSL , can you guys test the patch in D6865 ? i included both the arch and gentoo search paths so it should work out of the box now.
Yep - but not now. up to neck in alligators again. Never can tell what comes out of a Brooklyn sewer. Late this evening probably; post results in the wee hours Monday (-5 UTC, less wee +1 UTC).
Thanks thee, for the rapid turnaround!
Wait, what?! The 'again' is troublesome since it seems to indicate that this is a common occurrence....
Different, unrelated alligators. These are pink. Alligators related to build systems are putrid green, have warts, big teeth. Pink ones have been dispatched now. Starting cleanup...
@LazyDodo
D6865 plays fine here. Completely uneventful. Ran a couple of builds, one Release and one Debug from empty build directories. Deleted ##CMakeCache.txt## to make sure no strange symbols were floating around. Running ctest now; nothing out of the ordinary there either, up to now.
Current to: version: 2.83 (sub 3), branch: osl_rayfix, commit date: 2020-02-16 22:53, hash: f1a13b1ab8d6, type: Release
Thanks! Will test. :)
This comment was removed by @KyleDeVir
This completely resolves the issue! Thanks. :)
